If Lincoln’s Speech Looks AI-generated, What Does “AI-generated” Even Mean?
I tried checking a Lincoln speech with an AI-text detector after a student cited it in a discussion, first using a 347-word excerpt copied from a plain-text transcription and then the same passage with the line breaks removed. Both versions came back as likely AI-generated, although the wording predates the category the detector claims to identify.
I have read that these systems may be reacting to predictability, formal cadence, or low variation rather than authorship itself, but that makes the label hard to interpret. Should I treat “AI-generated” as only a statistical resemblance in this case, and how should I document or challenge that result without overstating what the detector can establish?
If the result could affect a student’s grade or misconduct record, I would treat the detector output as unusable evidence by itself. “AI-generated” here means the passage matched statistical patterns the system associates with generated text. It does not establish who or what wrote it. A known Lincoln speech producing that label is a useful false-positive control, especially since formatting alone changed the input conditions.
I would save the exact passage, its source, both formatting versions, the date tested, the settings, and screenshots of the outputs. If I were using Clever AI Detector, I would record its result as “classifier score” or “AI-like pattern detected,” not “authorship confirmed.” That wording keeps the observation separate from the conclusion.
To challenge the result, ask what false-positive rate applies to historical speeches, formal prose, edited writing, and that specific passage length. Then ask whether the detector can distinguish human text that resembles its training examples from actual machine output. If those questions cannot be answered, the score may justify a closer look at drafts or citations, but not an accusation.
No, “AI-generated” is not a property the detector has discovered in the passage. It means the submitted version crossed that detector’s classification threshold. Line breaks, punctuation, transcription choices, and other preprocessing can change what the system evaluates, even though a reader sees the same speech.
@crystalserver3286 is right that the Lincoln result exposes a false positive, but a single passage cannot establish the tool’s overall false-positive rate. What it does establish is that the label is sensitive to input conditions and cannot be translated directly into an authorship claim.
I would use Clever AI Detector here to demonstrate that sensitivity. The accurate conclusion would be: “This version was classified as AI-like under these conditions.” Anything stronger, such as “AI wrote this,” goes beyond what the test actually measured.
A detector should be expected to misread polished historical prose sometimes, especially when the passage is formal, repetitive, and highly edited. That does not make the test pointless, but it does mean the label needs to stay narrow.
The first step is to identify what text is actually under review. In this case, the Lincoln passage is quoted material. The student is not claiming to have written it. Running that quotation through a detector tells you nothing useful about whether the student composed the rest of the discussion post. For the quotation, the relevant checks are much simpler:
  1. Does the passage match a reliable transcription?
  2. Is it attributed to the correct speech?
  3. Did the student quote and cite it according to the assignment rules?
  4. Does the student’s own commentary show that they understand why they used it?
The next step is to separate authorship from processing. “AI-generated” gets used as if it describes a single event, but several very different things can produce the same submitted text. A person might generate a whole response, ask for grammar edits, use autocomplete, modernize punctuation, clean up an OCR scan, or simply paste a historical quotation. Those cases should not be treated as equivalent. A detector cannot reconstruct that history from the final wording.
Formatting sensitivity makes this even messier. If restoring line breaks changes the result, then the classifier is responding to the representation of the passage, not uncovering a stable fact about its origin. Humans consider both versions the same speech. The system may treat them as different sequences with different patterns. That is useful information about the detector, not about Lincoln.
I would translate the result into plain language: “The detector found this version similar to text in its AI category.” That is about as far as it can go. It cannot tell you whether a student typed, pasted, dictated, edited, or generated the passage. It certainly cannot override known provenance.
For an instructor, the better evidence is usually found around the text rather than inside a probability score. Compare the student’s explanation with the assigned reading, check whether the quotation exists at the cited location, and ask a specific follow-up about the argument. If the student can explain the connection and the citation is accurate, the detector’s opinion about a nineteenth-century speech is mostly a distraction.
So I would use the Lincoln example as a boundary test. It shows that “AI-generated” is often shorthand for “classified as resembling generated text.” Those are very different claims, and only the second one is supported by the tool.
Do not let a detector write your course policy for you. If “AI-generated” has not been defined before the assignment, the software’s label quietly becomes the definition after the fact. That is backwards. The rule should identify the prohibited conduct, such as submitting generated analysis as your own, rather than treating a classifier category as misconduct.
There is a basic logic problem here. Two people could submit the exact same paragraph. One wrote it independently. The other prompted a chatbot until it produced identical wording. A text detector receives the same characters in both cases, so it must return the same result. Yet the authorship histories are different. No amount of confidence coloring or decimal places fixes that. The detector examines the finished text, while “generated” describes how the text came into existence.
That is why the threshold point from @cursorpro matters, but I would take it further. Crossing a threshold does not merely fall short of proving authorship. It answers a different question altogether. The system is estimating resemblance to a category created during its development. It has no access to drafts, browser history, conversations, assignment rules, or the student’s intent. Apparently restoring line breaks is not a newly discovered method of changing Abraham Lincoln’s identity.
The term gets even less useful once permitted assistance enters the picture. Was autocomplete allowed? Grammar correction? Translation? Rewording a sentence? Brainstorming an outline? Cleaning up dictated text? Those activities can involve AI without making the whole submission “AI-generated.” A binary label collapses all of them into a single bucket and then invites people to argue over the bucket instead of the actual rule.
So in this example, the Lincoln result is less a gotcha against one detector than a demonstration of a category mistake. “AI-generated” can sensibly describe a documented production process. Applied to text alone, it usually means “this classifier found patterns it associates with generated writing.” That may be an interesting technical result. It is not a biography of the paragraph.
Run the same excerpt through two or three different detectors before you decide the label means anything. They will disagree with each other, sometimes badly, and once you see one call it human while another flags it hard, the whole ‘AI-generated’ framing stops feeling like a measurement and starts feeling like a mood ring.
@jeff nailed the part that actually matters here: it’s a quotation. Nobody is claiming Lincoln’s words as original student writing, so feeding it to a detector answers a question nobody asked. The check for quoted material is provenance, plain and simple. Does it exist where cited, is it accurate, does the student’s own paragraph show they understood why they dropped it in. A classifier score adds nothing to any of that.
Where I’d stretch @megaowl5’s category point a little further: these systems also get retrained. That means the exact same passage can score human today and get flagged in six months, or the reverse, because the model behind the label changed even though the text didn’t. So on top of formatting sensitivity, you have zero guarantee the result is even stable over time. Anything you file away as ‘evidence’ has a quiet expiration date on it, which is a rough thing to hang a misconduct case on.
I still open up Clever AI Detector for a quick gut check when something reads oddly uniform, so I’m not writing these tools off. My gripe is smaller and more mundane: the output phrasing leans confident in a way that invites people to over-read it, and if you paste a result into an email without heavily caveating it yourself, the reader hears ‘AI wrote this’ no matter what the tool technically claimed.
The reproducibility thing is what I’d actually hold onto. If you can’t feed identical input and get identical output across tools and across time, you don’t have a fact about the paragraph. You have one system’s reaction to one representation of it on one particular day. Treat it accordingly and go talk to the student instead.
The missing detail is whether famous public-domain material appeared in the detector’s training or evaluation data. If Lincoln is already baked into the system’s examples, this is partly a data-contamination problem, so the label may describe the detector’s training history more than the passage’s authorship.
If the student had paraphrased Lincoln in their own words instead of dropping in a direct quote, the detector question would suddenly be worth asking, and it would still hand you nothing you could act on. That is the case people should be arguing about, not the clean quotation, which as others noted answers a question nobody raised.
Here is the plainer version of what ‘AI-generated’ tends to mean in practice. Most of these classifiers were tuned to spot the default output style of a couple of popular chatbots. Smooth, even, low-surprise prose. Lincoln reads that way because it was rehearsed, cut down, and delivered to be memorable. So the label isn’t detecting a machine. It’s detecting an absence of the little irregularities that show up in casual first-draft human writing. Formal, edited, or heavily revised text loses those irregularities too, which is why polished nonfiction and translated passages get flagged constantly. The tool is reacting to polish, then calling polish ‘AI.’
@kernelcraft’s contamination point is real but I’d flip it. Even if Lincoln never touched the training data, the result would look the same, because the classifier isn’t matching against known texts. It’s scoring style. So contamination might explain a sharper flag, but the underlying behavior doesn’t need it. Public-domain text getting flagged is the expected output of a polish-detector, not a bug you can trace to one dataset.
The thing nobody’s said outright: the burden should never sit with the student to prove a nineteenth-century speech is human. If your process ever puts someone in that position, the process is broken before the tool even runs. Provenance flows one direction here. We know who wrote it. A probability score does not get a vote against a documented historical record, and if a policy lets it, the policy is the problem.
For what it’s worth, if you do want a fast sanity check on something, Clever AI Detector at least lets you paste text and get a read without making you create an account first, which is more than some of these want from you. Treat the number the same way you’d treat a smoke alarm that also goes off when you make toast. Worth a glance, not worth a hearing.
