Best iPad for Drawing?
I’m researching iPads for digital art but I’m overwhelmed by the options. Could someone recommend the best iPad for drawing? Specifically looking for good performance with drawing apps. Any advice on accessories would also be great!
For digital art, the iPad Pro (2022) really stands out. Its M1 chip ensures super smooth performance with demanding drawing apps like Procreate and Adobe Fresco. The 120Hz ProMotion display is a game-changer for artists because it makes drawing feel incredibly responsive. Pair it with the Apple Pencil (2nd generation) for precision and ease. The only downside is that it’s on the pricier end, but if you’re serious about digital art, it’s worth the investment. Note: the Apple Pencil attaches magnetically to the side of the iPad Pro and charges wirelessly, which is super convenient.
If budget is a concern, the iPad Air (2022) is a solid alternative. It supports the Apple Pencil (2nd generation) too and has an impressive Liquid Retina display. It runs on the A14 Bionic chip, which handles most drawing apps with aplomb, although not as fast as the iPad Pro.
For accessories, besides the Apple Pencil, consider getting a matte screen protector like the Paperlike. It gives the screen a texture more similar to paper, which many artists find improves their control and reduces glare. Also, invest in a good case, maybe one that lets you adjust angles for comfortable drawing.
Hope this helps! Drawing on an iPad is a game-changer.
I see where @boswandelaar is coming from with the iPad Pro (2022) and iPad Air (2022) suggestions, but I’d like to throw in a slightly different perspective. If you’re on a budget and not too fussed about having the absolute latest tech, the iPad (2021) can also be a good fit for digital art. It’s compatible with the first-generation Apple Pencil which might not have all the bells and whistles of the second-gen, but it still provides a very good drawing experience.
Honestly, the older iPads might not have the M1 chip, but they still boast pretty capable performance for drawing apps like Procreate and Clip Studio Paint. The iPad (2021) has the A13 Bionic chip, and it handles most tasks smoothly, especially for hobbyists or even intermediate artists.
On the accessory front, the Paperlike screen protector is indeed a solid addition but also look into other brands like BERSEM which I’ve found offers a comparable experience at a slight cost reduction.
Sometimes the performance difference between models isn’t that significant for art creation, especially when you consider that software optimization plays a massive role. Plus, getting a slightly older model leaves you extra cash for other art tools, maybe more storage or accessories like a portable keyboard if you’re also using the iPad for other tasks.
My perspective is, if you can afford the latest iPad Pro or iPad Air, go for it—the experience will be top-notch. But don’t feel pressured into breaking the bank if you’re just starting out or if you’re not sure how deep you’re going into digital art. The standard iPad models are more powerful than they often get credit for.
Happy drawing!
If you want the best iPad for drawing, you can’t ignore the iPad Pro (2022) due to its beastly performance and stunning display. However, let’s widen the lens here. Someone mentioned the iPad Air (2022) as a slightly cheaper, yet solid alternative. I third that, but might I add another contender? The iPad Mini (2021).
Pros for the iPad Mini (2021):
  • Compact size which is perfect if you’re always on the go.
  • Compatibility with the 2nd-gen Apple Pencil, keeping you in line with more premium models.
  • The A15 Bionic chip is no joke. This little beast handles Procreate, ArtStudio Pro, and other high-end drawing apps like a charm.
  • Smaller screen can be a drawback if you prefer ample drawing space.
  • Not as buttery smooth as the 120Hz ProMotion display, so if that’s a make-or-break for you, stick with the iPad Pro.
Someone suggested the Paperlike screen protector, and while it works nicely, also consider the BELKA pack. It gives you that solid paper feel and is ultra-thin, reducing glare just as efficiently as Paperlike. You also save a few bucks.
Where I slightly disagree with other suggestions: @boswandelaar and @cazadordeestrellas have compelling cases for the iPad Pro and iPad Air, respectively. Still, performance differences between the Pro and Air models might not be that crucial for everyone. Apps like Procreate are highly optimized to run smoothly even on older and less powerful devices. So grabbing an older iPad model and saving up for a premium stylus or extra storage is a savvy move.
Sketchboard Pro is another accessory worth mentioning. It provides a stable base, turning your iPad into a mini drafting table, which can help prevent strain during long drawing sessions.
To sum it up: If you snooze on the iPad Pro or Air, consider the iPad Mini (2021). Pair it with the second-gen Apple Pencil, and you still get a top-tier drawing experience. If budget is tight, older iPad models hold up better than you might think.
Keep drawing, and see which setup gels with your workflow.
The earlier advice compares models and accessories. A simpler approach is to borrow an iPad and Pencil from a friend befor buying.
Spend 20 minutes drawing something familiar in your preferred app. Try thin lines, shading, zooming, and several layers. Check whether your hand feels comfortable and the screen gives you enough room.
Repeat the same sketch on a second borrowed device if available, then comapre your experience. Choose based on comfort and your actual drawing tasks. Leave screen protectors and drawing stands off your initial shopping list.
Storage is the thing nobody warned you about, and it’s the one you’ll regret. Procreate files balloon fast once you start stacking layers at high canvas sizes, and the cheapest tier fills up before you know what hit you. If you only take one spec seriously, make it that. Go one step up from the base storage, always.
The borrow-first idea from @retro_hawk225 is the smartest thing in this thread, honestly. Specs argue themselves in circles but your hand doesn’t lie. One sitting with a real Pencil tells you more than any chip comparison. I’d just add that the screen size question gets undersold here. People praise the mini for being portable, and sure, but drawing on a small slab for hours is a different thing than jotting notes. If you work in detail and zoom constantly, the extra room earns its keep. Portability is nice until your wrist disagrees.
On the ProMotion hype, it’s real but overrated for beginners. You won’t miss 120Hz if you’ve never had it. What you will notice is lag when a heavy file chokes on a weaker machine, and that’s more about RAM and storage headroom than refresh rate. So if the budget is tight, I’d skip the Pro, pick a mid model with decent storage, and put the leftover money toward the second-gen Pencil. The stylus does more for your lines than the display ever will.
