Best note-taking apps for iPad?
Lost all my notes during an update and need a reliable iPad note-taking app. Any recommendations?
Man, losing notes during an update sucks—been there! If you’re looking for a reliable note-taking app for iPad, here are a few to check out:
  1. Notability – Great for syncing audio with your notes, which can be super helpful. It supports handwriting, typing, and even sketching.
  2. GoodNotes – Fantastic for handwritten notes. It has powerful search features and even reads your handwriting, making it easy to find specific notes later on.
  3. Microsoft OneNote – If you’re into the Microsoft ecosystem, OneNote integrates seamlessly. It’s a bit more chunky but pretty powerful and cross-platform.
  4. Evernote – Classic choice, very reliable, and works well across devices. It also supports various note types like text, reminders, and even web clippings.
  5. Nebo – Unique for its handwriting-to-text feature. It’s great if you prefer writing but want the flexibility of text editing later.
  6. Apple Notes – Don’t underestimate it. With cloud sync via iCloud, it’s simple but effective, especially if you’re already in the Apple ecosystem.
Give these a shot and see which one fits your workflow best. And whatever you do, BACK UP REGULARLY. Burned by updates too many times not to stress that enough. Good luck!
Whoa, bummer about the lost notes. Definitely backup regularly, like Chasseur said.
I would add to the list with Bear. It’s less talked about but super powerful for Markdown fans. You get easy formatting, great organization with nested tags, and it syncs smoothly with iCloud. It’s quite minimal but packs a punch if you like clean interfaces.
Another interesting one is LiquidText. If you deal with PDFs or research a lot, this is a game-changer. You can pull excerpts from PDFs and link them directly to your notes. Pretty neat for academic or detailed project work.
Lastly, I’ll throw in a curveball—Zoho Notebook. I don’t see it get much spotlight, but it’s actually pretty solid. You can create different types of notes like checklists, audio notes, etc., and it syncs across devices.
Not that Apple Notes isn’t good, but personally, I find it lacks some advanced features unless you just need basic note-taking. Chasseur’s list covers many bases; add some of these into the mix, and you should have a great app suite to try out. Cheers!
You’re not alone; losing notes during an update is the worst! @cacadordeestrelas and @chasseurdetoiles have listed some solid options, but I’d say let’s not overlook some lesser-known gems.
NoteMaster
  1. Versatile Input:
    • Supports text, handwriting, and audio recording.
  2. Rich Media Support:
    • Easily embed images, sketches, and even web clippings.
  3. Cross-Platform Syncing:
    • Smooth sync across iPad, iPhone, and desktop.
  1. Complex UI:
    • Might be overwhelming for beginners.
  2. Cost:
    • On the pricier side compared to some alternatives.
UPAD3
  1. Handwriting Experience:
    • Mimics paper-like writing, incredibly fluid.
  2. Document Management:
    • Annotate PDFs efficiently.
  3. User-Friendly:
    • Intuitive interface, easy to navigate.
  1. Limited Format Options:
    • Not as versatile in text formatting.
  2. Less Known:
    • Slower updates and user community size.
General Tips:
  1. Backup Regularly: iCloud or Google Drive can be your best friends.
  2. Consider Ecosystem: If you’re deep into Apple, sticking with Apple Notes or any other app with strong iCloud integration can be beneficial.
Additional Picks:
  • MarginNote: Ideal for heavy research with mind-mapping tools, though the learning curve is steep.
  • Noteshelf: Great for blending handwriting and typed text, and integrates well if you use an Apple Pencil frequently.
When you’re grinding out hours of notes, ANY mishap sucks, but a well-chosen app can save you a ton of headaches. Make sure to test out a few before diving in completely. And hey, don’t sleep on updating your backups, seriously.
Strong list. NoteMaster brings text, handwriting, audio, and cross device sync, though UI feels busy and pricey. UPAD3 excels at handwriting and PDFs, with fewer formats and slower updates. MarginNote suits research. Noteshelf fits Pencil users.
Alternative, simpler fix: go file based. Create an iCloud Drive folder named Notes. Use IA Writer or 1Writer. Save each note as plain text or Markdown. Every note stays as a file, no database. Lower corruption risk. Files keeps deletions 30 days for quick restore if stuff goes wrong. Occassionally zip teh folder for an extra copy.
