Best Way To Recover Deleted GoPro Video After Accidental Deletion? Need Help
I accidentally deleted an important GoPro video from my SD card before backing it up, and I really need to recover it. The footage was from a special trip, and I’m hoping someone can share the best GoPro video recovery methods or software that actually works without causing more data loss.
I’ve had to recover lost GoPro clips more than once, and it’s one of those jobs where the usual photo recovery advice falls apart fast. Sometimes the footage is still sitting on the card. Sometimes you get a file name back and a dead video. That part trips people up.
Start here
Stop using the SD card right now.
Don’t shoot more footage. Don’t format it. Don’t run random fix tools you found in a forum thread from 2017. Once new data lands on the card, old video chunks get overwritten, and your odds drop hard.
Before you install anything, I’d check a few simple spots first:
  1. GoPro cloud Trash or Recently Deleted, if your account has cloud backup
  2. Any copy you dumped to your PC, external SSD, or NAS and forgot about
  3. LRV files on the card, since those preview clips are small but sometimes better than nothing
  4. The camera’s own repair prompt after you reinsert the card
If none of those pans out, then yeah, recovery software is the next move.
Why GoPro recovery gets messy
I used to think deleted video recovery worked like deleted JPG recovery. It doesn’t. Not close.
With newer action cams, the recording usually isn’t one clean MP4 written in one straight line. A GoPro tends to write multiple pieces at once, main video, preview files, audio, GPS info, thumbnails, metadata, and other bits. On the card, those pieces often end up scattered all over.
So a scanner might find an MP4 signature, glue some parts together, and still hand you a file players refuse to open. I’ve seen this with clips where the size looked right, the name looked fine, and the file was junk.
This shows up a lot with:
  1. GoPro Hero models
  2. DJI drones
  3. Insta360 cameras
  4. Recent Sony, Canon, Nikon, and Panasonic cameras
  5. Dash cams
For this kind of loss, the scan alone isn’t the whole story. The rebuild step matters a lot.
What I’d try first
I’d start with Disk Drill.
The reason is simple. Its Advanced Camera Recovery mode was made for broken-up camera footage, not plain deleted office files. Instead of assuming your video lived in one clean chunk, it tries to piece together fragments in the right order and turn them into something playable. For GoPro cards, drone cards, dash cam storage, stuff like this, that approach makes more sense.
The workflow is short:
  1. Put the SD card in a card reader
  2. Open Disk Drill
  3. Select the card
  4. Pick Advanced Camera Recovery
  5. Run the scan
  6. Preview what it finds
  7. Save recovered files somewhere else, not back to the same card
The preview part helps. I like seeing whether a clip opens before I waste time saving a pile of bad files. I’d also pay attention if the software suggests making a byte-to-byte image first. I’ve done that on flaky cards, and it saves you from hammering unstable media over and over. Kinda boring step, but worth it.
Other options people bring up
PhotoRec is the free fallback I’d keep around.
It finds a ton of file types, and it costs nothing. The tradeoff is rough. No dedicated camera video reconstruction, no preview, no friendly sorting. You often end up with a mess of recovered files and have to inspect them one by one. I’ve done it. It sucks, but if free is the requirement, it’s still useful.
UFS Explorer is on the other end.
It’s stronger than a lot of consumer tools once things get ugly, though it asks more from you. The interface is less forgiving, and it still doesn’t give you the same focused camera-recovery path Disk Drill has for fragmented action cam footage. If you already know your way around recovery software, it’s worth a shot. If you don’t, you might spend half your time second-guessing every option.
My rough order
If I deleted footage from a recent GoPro, DJI drone, or similar camera, I’d do it like this:
  1. Check cloud trash, backups, LRV files, and camera repair prompt
  2. Run Disk Drill first
  3. Use PhotoRec if I needed a free second try
  4. Move to UFS Explorer if the case looked worse and I needed more control
From what I’ve seen, GoPro recovery is one of those cases where “it found the file” means almost nothing by itself. What matters is whether the software rebuilds the clip into something you can play. That’s the part people miss, and yeah, I missed it too the first time.
First thing, pull the SD card and leave it alone. If you already filmed more stuff after the deletion, recovery odds drop fast.
I agree with part of what @mikeappsreviewer said, but I would not start by bouncing the card back into the GoPro over and over hoping the camera fixes it. If the card has weak sectors, each write hurts you. Read-only approach first. That matters more than people think.
What I’d do:
  1. Put the card in a good USB card reader, not the camera.
  2. Make a full image of the SD card first. Use Disk Drill or any imaging tool. Work from the image, not the original card.
  3. Scan the image for deleted video.
  4. Recover files to your computer or external drive, never back to the SD card.
  5. Test the recovered MP4 in VLC. VLC opens damaged files better than the default player.
If the recovered GoPro file shows up but won’t play, try a repair tool like Grau Video Repair or fix.video. GoPro clips often lose the moov atom, so repair matters as much as recovery. That part gets skipped a lot.
Disk Drill is a solid first pick for GoPro video recovery because it handles SD cards well and gives you a faster workflow than a lot of older tools. I’d still image the card before scanning, tho.
Also, check for the low-res .LRV file. Not ideal, but better than losing the trip footage entirley.
Helpful quick guide here too:
recover deleted SD card video files fast
I’d actually split this into two separate problems: recovery and repair. @mikeappsreviewer focused more on the recovery side, and @sonhadordobosque is right about imaging first, but neither point fully solves the annoying part where the GoPro clip comes back and still refuses to play.
What I’d do different:
  • check the card on a computer with show hidden files enabled
  • look for split chapter files too, not just the main MP4
  • if your GoPro made a THM/LRV pair, keep those with the recovered file because sometimes they help identify the right clip set
  • after recovery, run the video through a repair utility if VLC stutters or shows black frames
For the actual undelete part, Disk Drill is still a sensible choice because GoPro video recovery is messy and SD card recovery tools are not all equal. But I would judge success by whether the recovered file plays start to finish, not whether the filename looks right. Big difference.
One more thing people skip: if the card was exFAT and the deletion was recent, recovery odds are usually better than after a full format. If the camera shot more footage after, yeah… that’s where it gets ugly fast.
Also worth reading:
GoPro video recovery tips from this Facebook discussion
If you want, post the GoPro model, card size, and whether the file was deleted or the card was formatted. That changes the best move a lot.
