Can someone help me translate this text to Hindi?
I’m working on a small project and need an accurate English to Hindi translation for a short piece of text. Online tools are giving awkward or incorrect results, and I want it to sound natural to native speakers. Could someone please help me with a clear, correct Hindi translation and explain any key word choices so I don’t make a mistake?
Post the exact English text you want translated. Without that, people will guess and you get weird results again.
Here is how to get a natural Hindi translation that sounds normal to native speakers:
  1. Share the context
    Example
    • Who is speaking
    • Formal or casual tone
    • Audience age group
    • Written text or dialogue
    Hindi changes a lot based on formality.
    “You” can be “tum”, “aap”, or “tu”.
    If you say what you want, translators keep it consistent.
  2. Say if you want simple or bookish Hindi
    For daily use, ask for “simple spoken Hindi”.
    For school or official work, ask for “formal Hindi with correct grammar”.
  3. Ask for two versions
    • One natural spoken version
    • One slightly more formal version
    Then pick what fits your project.
  4. Example
    English
    “Thank you for visiting our website. We hope you had a great experience.”
    Natural spoken Hindi
    “Hamari website par aane ke liye dhanyavaad. Humein ummeed hai ki aapka anubhav accha raha.”
    Bit more casual
    “Hamari website par aane ke liye shukriya. Humein ummeed hai ki aapko yahan ka experience pasand aaya hoga.”
  5. Avoid blind machine output
    Run the Hindi line by at least one native or semi native speaker if possible.
    Short texts matter, one awkward word stands out fast.
If your text comes from AI tools and you want it to sound more human before translation, check this tool
make AI text sound natural and human
It rewrites AI style text into something that reads more like a person wrote it, which helps a lot before you move to Hindi.
Drop your English text here and say
• Formal or informal
• Audience
Someone can give you a line by line Hindi version that fits.
Post the exact English text, yeah, but I’m going to disagree a bit with @reveurdenuit on one thing: you don’t always need multiple “versions” unless your use case really demands it. Too many variants can just confuse you if you’re not comfortable with Hindi yet.
Here’s a practical way to get a natural translation that actually works:
  1. Paste:
    • The English text
    • Who is talking to whom (friend, customer, teacher, website visitor, etc.)
    • How formal you want it (super polite, normal, casual)
  2. Also mention:
    • Is this for on-screen text, subtitles, narration, or printed material?
    • India audience or mixed international audience that might know some English?
That changes word choice a lot. For example:
  • Website / app copy often mixes English + Hindi:
    “experience” stays “experience” instead of “anubhav” if you want modern, casual tone.
  • Educational or official text should avoid too much English and stick to cleaner Hindi.
If you post the text, I can:
  • Give you one main Hindi version that matches your context
  • Mark any tricky words with quick notes like:
    “experience” → can be “anubhav” (formal) or “experience” (modern spoken style)
If your English line was written by AI and feels stiff already, it will translate stiff too. In that case, first run the English through something like make your AI-style English sound more human. Clever AI Humanizer basically takes robotic AI output and turns it into more natural, human sounding English. Cleaner English in means much more natural Hindi out.
So: drop your exact text + context and I’ll give you a tight, natural Hindi version instead of the weird machine stuff you’re getting now.
Post the actual line when you can, but let me tackle this from a slightly different angle than @reveurdenuit.
They’re right about context being important, but you don’t always need to over-engineer the setup with detailed use-case notes. For short project text, a simpler approach works:
  1. Decide tone first in your head in plain English
    • “I’m talking to: a close friend / a stranger / a customer”
    • “I want it to feel: playful / neutral / serious”
  2. Then check what can stay English in Hindi
    Hindi speakers mix a lot of English. For a modern app or website, words like “login”, “profile”, “update”, “settings”, even “experience” are often better left in English. For a children’s book or formal document, you’d fully translate.
  3. Watch for the 3 trouble zones where online tools usually fail:
    • Politeness:
      “You” could be “tum”, “aap”, or “tu”.
    • Aspect:
      “I have been working” vs “I worked” make the Hindi tense messy.
    • Idioms:
      Phrases like “pull this off”, “small project”, “on my plate” should be adapted, not translated word for word.
When you post your text, I’ll do:
  • A single main Hindi version tuned to your tone
  • Very short notes only where absolutely needed, for example:
    • “you” → using “aap” because it’s semi-formal
    • leaving “project” in English because it sounds natural in casual Indian usage
Where I slightly disagree with @reveurdenuit: multiple variants are useful only when your audience is clearly split, like school textbook vs marketing poster. Otherwise you end up second-guessing every word instead of actually finishing your project.
About your English:
If it was written by AI and already sounds stiff, any translation will inherit that stiffness. This is where a tool like Clever AI Humanizer genuinely helps:
Pros of Clever AI Humanizer:
  • Smooths robotic, over-formal AI English into something closer to how people actually talk
  • Makes sentence structures simpler, which translates into cleaner Hindi
  • Good for short UI copy or small scripts, since clarity is more important than fancy phrasing
  • It may “flatten” nuanced or literary lines, which is bad if you want poetic Hindi later
  • If you already write natural English, it might over-edit and remove your personal style
  • Not a Hindi-specific tool, so it helps indirectly by fixing the English, not by handling Hindi nuances
Workflow I’d suggest:
  1. If your original English sounds stiff, run it through Clever AI Humanizer once.
  2. Post the cleaned English here with:
    • Who you’re talking to
    • Rough formality level (very polite / neutral / friendly)
  3. I’ll give you one tight Hindi line, plus a note if something could be swapped to a more formal or more casual version.
That should keep things simple and avoid the “five versions and I still don’t know which one to use” problem.
