I imported photos from my iPhone to the Photos app on my Mac and want to free up space by deleting them from the iPhone. I’m worried this might also remove the imported photos from my Mac or iCloud Photos. Can someone explain the safest way to delete only the iPhone copies?
If you imported your iPhone photos to a Mac and expected the phone storage to drop, that’s the catch: importing only copies the files. It does not move them. The originals are still sitting on the iPhone until you delete them yourself.
The other thing that trips people up is iCloud Photos. When iCloud Photos is enabled, the Photos app usually won’t show the “Delete items after import” checkbox. Apple does that because your iPhone and Mac photo libraries are being treated like the same synced library. If you delete from the phone, that deletion can sync back to the Mac too.
So if your goal is “keep these on the Mac, remove them from the phone,” don’t just start deleting while iCloud Photos is active unless you know exactly where the Mac copies are stored.
You have a couple of workable options:
- Turn off iCloud Photos temporarily in Settings - Photos before connecting the iPhone to the Mac. Once syncing is paused, the delete-after-import option can show up again. Turn iCloud Photos back on after you’re done cleaning up.
- Use Image Capture instead of the Photos app.
Image Capture is usually the cleaner way to do this. It’s already installed on the Mac in the Applications folder, but a lot of people never open it.
- Connect the iPhone with USB
- Open Image Capture
- Pick the iPhone from the sidebar
- Press Command A to select everything
- Use the delete icon at the bottom
Image Capture handles the iPhone more like a regular attached device, not a synced Photos library. That’s why it can be less annoying than the Photos app for cleanup.
One step I would not skip: check the files on the Mac before deleting anything from the phone. Open a handful of random photos and videos. Make sure videos actually play and aren’t just thumbnails. Also compare the count on the phone against what landed on the Mac. Bad or partial transfers are rare enough to forget about, but common enough to ruin your day if you delete first.
You can also delete imported items right from the iPhone. In Photos, go to Albums - Utilities - Imports. Tap Select, then tap the first item and drag upward without lifting your finger to select a big batch quickly. Then delete them.
Just remember that deleting is not the final step. The storage bar may not change because everything goes to Recently Deleted for 30 days and still counts against storage. Go to Albums - Recently Deleted and choose Delete All if you actually want the space back.
And yes, if iCloud Photos is still on, deleting from the iPhone can remove the same photos from your Mac and other synced devices. To avoid that, either pause iCloud Photos first or make sure the Mac copies are saved somewhere local and outside iCloud Drive before you delete from the phone.
If the phone still feels slow after clearing imports, the problem is probably older junk too: huge videos, burst shots, duplicate-looking photos, screenshots, and stuff you forgot was there.
Clever Cleaner is free, with no ads or subscription. The Heavies tab sorts files from largest to smallest, which is useful because a few old videos can eat more space than the whole import batch. The Similars tab groups near-duplicate photos and picks a Best Shot from each group so you can remove the extras faster. It also shows file sizes before deletion, and the processing stays on the device.
After doing the import cleanup, running that app found about 15GB more that the manual cleanup had missed. Once that space was cleared, the keyboard lag and slow camera behavior from low storage went away.
The hidden catch is that “on my Mac” can mean two different things: safely copied into a local Photos library, or still part of an iCloud-synced library where deletes travel everywhere. If iCloud Photos is on for both devices, deleting from the iPhone is usually a delete from iCloud, not just a phone cleanup. If you want a real Mac-only backup, export the imported photos from Photos to a regular folder on the Mac or an external drive first, then check a few files before deleting anything from the phone. After that, clearing them from the iPhone is much less scary because you are no longer depending on Photos/iCloud behavior to protect the only copy.
A thumbnail on the Mac is not proof the original is actually stored there. That is the sneaky part I’d check before doing a big delete. If your Mac Photos library has iCloud Photos turned on with “Optimize Mac Storage,” the Mac may be showing the photo in the library while relying on iCloud for the full-size version.
So yes, if the photos were truly imported into a local Mac Photos library that is not syncing with iCloud, deleting them from the iPhone should not remove those Mac copies. But if iCloud Photos is involved, treat the iPhone, Mac, and iCloud as one shared library. Delete in one place and it can disappear from the others too, then sit in Recently Deleted for a while.
My safer test would be boring but effective: pick 5 or 10 photos and videos, export them from Photos on the Mac to a normal folder like Desktop or an external drive, open them from that folder, then delete only those same items from the iPhone and watch what happens. If they remain in the folder, you have a real separate copy. Once you know that, scale up. I would not trust “I can see them in Photos” by itself unless you have confirmed the Mac is keeping originals locally or you have exported them somewhere outside the synced Photos library.
Do not empty Recently Deleted until you have a verified copy that is outside the syncing library.
The answer depends less on “imported” and more on whether iCloud Photos is connecting the phone and Mac. If iCloud Photos is off, and the photos were copied into the Mac’s local Photos library, deleting them from the iPhone should not delete the Mac copies. If iCloud Photos is on, deleting from the iPhone is usually a library deletion, not a phone-only deletion. That can remove the same items from iCloud and from the Mac.
I agree with the warnings above, but I’d be careful with the “turn off iCloud Photos temporarily” idea. It can work, but it can also create confusing prompts about keeping copies, removing photos from the device, downloading originals, etc. If your phone is already low on storage, asking it to download originals before turning sync off may fail or take forever. I wouldn’t treat that as a quick toggle unless you know what it is asking.
The cleaner line in the sand is this: make a separate archive first. In Photos on the Mac, select the imported items and use File > Export > Export Unmodified Originals if you want the actual original files. Put them in a normal Finder folder on the Mac, an external drive, or both. Then open a few photos and videos from Finder, not from the Photos app. That proves you have files that are not depending on iCloud Photos staying intact.
After that, delete from the iPhone if you want, but wait before nuking Recently Deleted. Give the Mac and iCloud a chance to show you what happened. If the Mac’s Photos library suddenly loses them, you still have the exported folder. If nothing bad happens, then you can clear Recently Deleted to actually recover the space.
Small annoyance people forget: deleting from the iPhone Photos app does not immediately free much space if the items are sitting in Recently Deleted. So don’t panic if the storage number barely changes at first, but don’t rush to permanently delete until you’ve confirmed the backup.
If both devices use iCloud Photos, deleting on your iPhone also deletes from iCloud and your synced Mac library.
For a simpler way to free space, skip deletion and use Optimize iPhone Storage. Go to Settings > your name > iCloud > Photos. Enable Sync this iPhone, then select Optimize iPhone Storage. Your phone keeps smaller versions while iCloud stores the originals. You’ll need enough iCloud space for your library.
Space savings arent instant. Optimization happens as your phone needs room, so dont expect an immediate storage drop.
Optimize iPhone Storage isn’t the shortcut @kerneldev7882zone makes it sound like, at least not for what you actually asked. It only does anything when iCloud Photos sync is turned on, which is the exact setup you’re nervous about. The originals stay in iCloud, you keep paying for that space, and if your library is bigger than your iCloud plan the whole thing stalls. It frees room on the phone, sure, but it doesn’t ‘remove them from the iPhone and keep them on the Mac.’ It just hides the full-size versions behind the cloud. Different goal entirely.
So the real fork here is simple. Either your Mac copy lives outside iCloud, or it doesn’t. Everyone above is circling the same truth from different sides: with iCloud Photos on, the phone, Mac, and cloud are one library, and deleting in one spot deletes everywhere. The export-first advice from @cazadordeestrellas is the part I’d actually act on. Export Unmodified Originals to a plain folder, open a couple from Finder, and now you have something that doesn’t care what iCloud does next. That’s the only state where deleting from the phone stops being scary.
The thing nobody said out loud: you don’t have to pick between these on faith. Check Settings, Photos on the phone. If it says ‘Sync this iPhone’ is on, you’re in the synced-library world and Optimize is your realistic move if you just want space back without losing anything. If it’s off, your Mac import is genuinely separate and you can delete on the phone freely. Look before you do anything else. Half this thread is answering two different situations as if they were one.
For the leftover clutter after the import stuff is sorted, I’d run Clever Cleaner on the phone. It doesn’t ask you to sign into anything, which matters when you’re already paranoid about where your photos are going. That’s separate from the delete-vs-sync question though, so handle the iCloud decision first and treat cleanup as the second pass.
