I turned on Optimize iPhone Storage because my iPhone was almost full, but I’m not seeing any storage free up yet. I’m trying to figure out if this setting works immediately or if it takes time for photos and videos to optimize. Need help understanding how long Optimize iPhone Storage usually takes and whether there’s anything else I should do.
Apple’s storage page trips up a lot of people. I got stuck on “Optimize iPhone Storage” too, mostly because the wording makes it sound simpler than it is. What it does is pretty specific.
What happens to your photos after you switch it on
This setting only works with iCloud Photos. They’re tied together. If iCloud Photos is enabled and you pick Optimize iPhone Storage, your phone stops keeping every original file on the device. The full quality versions sit in iCloud, and your iPhone keeps smaller copies for everyday browsing.
You still see the whole library in Photos. Nothing looks missing. But when you open an image and start editing, cropping, or zooming in, the phone fetches the original from iCloud. If you’ve noticed a small loading spinner on a photo, ths is usually why.
If iCloud Photos is off, Optimize Storage does nothing. There’s nowhere else for the originals to live, so the phone keeps them on local storage until you run low.
Videos count too
Yep. And for a lot of people, videos are the main reason storage disappears so fast. One minute of 4K at 60 fps can land around 400 to 500 MB depending on encoding and scene detail. So when people turn this setting on and suddenly free up a chunk of space, it’s often the video library doing most of the work.
It does not clear space all at once
This part threw me off. I expected an instant cleanup. It doesn’t work like tht.
The system adjusts over time. Recent photos and videos often stay on the phone in full resolution for faster access. Older stuff gets pushed to iCloud first, usually when local storage starts getting tight. If your library is big, the first sync and optimization pass might take minutes or it might drag on for hours. Mine moved faster on Wi-Fi while plugged in.
If it keeps shutting off or stops helping
I ran into two usual suspects.
One is a mismatch across devices on the same Apple ID. If another iPhone, iPad, or Mac is set to download originals, things get messy and people assume Optimize is broken.
The other problem is simpler. Your iCloud storage is full. Apple gives 5 GB free, which disappears fast if you shoot photos and video often. Once iCloud runs out of room, the phone has nowhere to offload originals. At tht point optimization stalls. If you open Settings, tap your Apple ID, then iCloud, you’ll often see a warning or a red exclamation mark when this is the issue.
What happens when you turn Optimize Storage off
Your iPhone starts pulling the original files back down to the device. If you’ve got a large library, this can take a while and it can eat through free space fast. I’d check available storage first before touching tht toggle, or you end up swapping one storage problem for another.
Why this setting doesn’t solve everything
Even when it’s working right, your library still includes all the junk you saved over time. Duplicate pictures. Burst shots where 18 frames are almost the same. Blurry misses. Random 4K clips you forgot existed. iCloud keeps all of it. Optimize Storage only changes where files are stored. It does not sort, trim, or remove any of the clutter.
Clever Cleaner is the part I used for tht cleanup. It’s free, no ads, no subscription. The Heavies section puts the biggest files at the top, so the giant videos show up first instead of being buried. The Similars section groups near-matching photos and picks a best shot from each set, which helped me get rid of repeat attempts and burst leftovers fast. The processing stays on the device, so nothing gets uploaded somewhere else.
After I cleared duplicate shots and large videos, Optimize Storage started behaving the way I expected in the first place. The phone stopped feeling cramped, and the slowdown I kept noticing from low storage eased up.
No, it usually does not free space right away.
Optimize iPhone Storage works in the background. Your iPhone has to upload full originals to iCloud Photos first, then swap some local files for smaller versions. If your phone is low on battery, off Wi-Fi, or short on iCloud space, the cleanup slows down or stalls. Sometimes it takes hours. On a big library, it takes longer.
One thing I’d add to @mikeappsreviewer, the phone often waits until storage pressure gets worse before it gets agressive. So you might turn it on and see almost no change at first. Then later, after charging overnight on Wi-Fi, you see a few GB open up.
Check these 4 things:
- iCloud Photos is on.
- You have free iCloud storage.
- You’re on Wi-Fi.
- Your phone is plugged in.
Also look at Settings, General, iPhone Storage. If Photos is still growing, sync is still in progress.
If you need space now, Optimize won’t be fast enough by itself. Remove large local junk first. Clever Cleaner helps with duplicate photos, similar shots, and heavy videos. It’s one of the better iPhone cleaner apps for clearing photo clutter fast. This video explains the photo storage side well: how to free up iPhone photo storage faster.
So yes, it works. No, not instnatly.
Nope, not straight away in most cases.
I mostly agree with @mikeappsreviewer and @vrijheidsvogel, but I’d push back on the idea that you should expect a visible drop super quickly just because the toggle is on. Apple is pretty conservative with this stuff. It usually waits, checks conditions, then gradually replaces full-res local copies with smaller ones. So if you just enabled it 10 minutes ago, that means basically nothing yet.
A few things people miss:
- Low Power Mode can slow background photo stuff
- a bad/spotty Wi-Fi connection can stall it even if Wi-Fi is technically ‘on’
- if your phone is extremely full, iOS can get weirdly slow about housekeeping
- recently viewed or recently shot photos/videos may stay local longer than you want
Also, the Photos storage number in iPhone Storage is not always instanty accurate. Sometimes it lags behind real cleanup. I’ve seen it look stuck, then jump later after a restart or after being left charging overnight.
If you want to check whether it’s doing anything, open Photos and scroll way back into older videos. If some take a second to sharpen/load, that’s often a sign optimization is happening.
And bluntly, Optimize iPhone Storage is not a magic ‘clean my phone now’ button. It’s more like a slow pressure-release valve. If you need space today, delete big attachments, offline downloads, and giant videos first. Clever Cleaner can help if your storage problem is mostly duplicate pics, similar shots, and oversized media. Also, this Cult of Mac review of a truly free iPhone cleaner app gives a decent overview.
So yeah, it works, but it can take hours, sometimes a day or two. Apple made it sound way more imediate than it really is.
Not instantly. I agree with @vrijheidsvogel, @chasseurdetoiles, and @mikeappsreviewer on the big picture, but one small nuance: people often assume the toggle itself triggers an aggressive cleanup. In practice, iOS treats it more like a storage policy than a one-time action.
A useful way to think about it:
- Turning it on changes what iPhone is allowed to remove later
- It does not mean every old original gets evicted right away
- The biggest gains usually appear after the phone has had time to sit idle
Also, the free space you get is not always proportional to your whole library. If a lot of your storage problem is apps, messages, downloads, or cache bloat, Optimize Photos won’t move the needle much.
One thing worth checking that hasn’t been stressed enough: your oldest media may optimize before your newest, but your favorite or frequently opened items can stick around locally longer. So two people with the same photo count can see very different results.
If you need immediate room, trim non-photo stuff first, then let Optimize catch up in the background.
If your photo library itself is messy, Clever Cleaner can help before optimization really pays off.
- fast way to spot duplicate and similar shots
- helps find large videos eating storage
- easier than hunting manually in Photos
- it won’t replace iCloud optimization
- you still have to review before deleting
- best results depend on how cluttered your library actually is
So yes, it works, but usually on Apple’s schedule, not yours.
Optimize iPhone Storage takes time and often waits until your iPhone needs more room. For faster results, move older photos and videos to a computer or external drive.
Connect your iPhone with a cable, import the files through Photos or Image Capture, then confirm the orginals copied correctly. Delete those items from your iPhone and empty Recently Deleted. This frees storage immediatly, without waiting for iCloud optimization. Start with long 4K videos since one minute often uses 400 MB or more.
The originals have to finish uploading to iCloud before your phone will swap in the smaller copies, and on a big library that upload alone can drag on for a day or two. So if the initial sync isn’t done, Optimize has nothing to work with yet. @bluenode4179’s cable import is honestly the quicker fix if you need room today.
