My iPhone storage is almost full, and I’m running out of space for photos, apps, and updates. I’ve deleted a few things, but it still fills up quickly. What are the best ways to free up iPhone storage or add more space with iCloud or other options?
You can’t really “add storage” to an iPhone in the normal sense. Some repair places talk about swapping the storage chip, but that’s not a simple upgrade. It’s expensive, risky, and you can end up with a phone Apple won’t want to touch afterward. For most people, the better answer is boring but effective: clear out the storage you’re already wasting.
Start by checking where the space is going. Go to Settings > General > iPhone Storage. If your phone is always full, there’s a good chance Photos is near the top.
iOS is not great at helping you clean things up quickly. Apps, Messages, downloads, and random documents usually need to be handled one by one. Photos and videos are where you can usually make the biggest dent, though, especially if you take lots of burst shots, screenshots, or videos and never go back through them.
That’s why I’d start with a photo cleanup app. The one I’d point people to is Clever Cleaner. A lot of “free” cleaner apps are basically subscription traps, where they scan your library and then make you pay to actually delete anything useful. Clever Cleaner is currently free, has no ads, and lets you clean up your photo library without paying.
The most useful part is Similars. It doesn’t only look for exact duplicates. It groups photos that are close enough, picks what it thinks is the best one, and lets you delete the extras pretty quickly. That usually saves more space than Apple’s built-in Duplicates album, because most wasted photo storage is not perfect copies. It’s five versions of the same shot.
The Heavies section is also worth checking. It sorts your largest videos automatically, which is helpful because a few old 4K clips can eat several GB by themselves. Sometimes deleting three or four videos makes a bigger difference than cleaning up hundreds of photos.
Turn on Optimize iPhone Storage
After you’ve deleted the obvious junk, go to Settings > Photos > Optimize iPhone Storage and turn it on. This keeps smaller versions of your photos on the iPhone and stores the originals in iCloud. When you open a photo, the full-quality version downloads as needed.
It’s an easy way to cut down local storage use, but the catch is iCloud space. Apple only gives you 5 GB for free, so that may not be enough if you have a large library. If you don’t want to delete older photos and videos, moving some of them to another cloud service like Google Drive can also help.
Use external storage if you shoot a lot of video
If your storage problem mostly comes from long videos, especially 4K or ProRes, an external drive might be worth it. Lightning and USB-C flash drives can be used to move finished files off the phone. Some camera apps can also record straight to compatible external storage, which keeps huge video files from filling up the iPhone in the first place.
Know when cleaning is not enough
If you’ve cleaned out Photos, deleted unused apps, turned on storage optimization, and you’re still constantly fighting the storage warning, the phone may just not have enough capacity for how you use it.
A 64 GB or 128 GB iPhone can be fine if you don’t keep much on it. But if you shoot a lot of video, keep a large photo library, download media, or install a bunch of large apps, it gets tight fast. You also need some free space left over for iOS updates and normal background stuff.
Still, I wouldn’t jump straight to buying a new phone. Do a real cleanup first. In a lot of cases, removing similar photos and large videos with Clever Cleaner, then manually clearing apps, downloads, and messages, can recover tens of gigabytes and buy you a lot more time.
You probably won’t turn a nearly full 64 GB iPhone into a roomy phone without changing habits, paying for cloud storage, or moving stuff off the device. The internal storage is fixed, so the real choice is whether you want to delete, offload, or store files somewhere else.
A thing people miss is that iCloud Photos is not the same as an extra hard drive. If iCloud Photos is turned on and you delete photos from the iPhone, they usually delete from iCloud too. “Optimize iPhone Storage” helps by keeping smaller copies on the phone, but you still need enough iCloud storage for the originals. If you want photos completely off the phone, export them to a computer, external drive, Google Photos, OneDrive, etc., then make sure they are safely there before deleting from the iPhone.
For a quick cleanup, check the boring stuff first: empty Recently Deleted in Photos, clear downloaded movies/music/podcasts/maps, delete old iMessage attachments, and offload apps you rarely open. Some apps like TikTok, Instagram, Safari, Spotify, and messaging apps can build up a lot of cache, and iOS does not always show a nice “clear cache” button. Sometimes deleting and reinstalling the app is the fastest fix, as long as you know your login and nothing important is stored only inside that app.
Don’t start by nuking photos or message threads until you know they’re backed up somewhere you can actually restore from. The fastest safe move is to go to Settings > General > iPhone Storage and attack the top few categories, not the tiny stuff. If Photos is huge, export old videos first, because videos are usually the real space hog. If Messages is huge, set it to keep messages for 1 year or 30 days instead of forever, but only if you’re fine losing old attachments. For apps with bloated “Documents & Data,” deleting and reinstalling can work, but be careful with apps that store projects, recordings, games, or files locally. And if “System Data” is the mystery chunk, restart the phone, update iOS if there’s room, and leave a few GB free for a while. iPhones behave worse when they’re constantly at 99% full.
A phone with 8 or 10 GB free is a cleanup problem; a phone with a few hundred MB free is an emergency-room problem. If you’re in the second case, don’t start with tiny stuff like deleting contacts, notes, or a couple of apps. Get one big chunk back first so the phone can breathe.
The fastest “ugly but effective” move is usually to remove downloaded media. Check Netflix, Disney+, YouTube, Spotify, Apple Music, Podcasts, Maps, Kindle, Audible, and any offline video apps. People forget those because they don’t always show up as obvious files, but one downloaded season or a few podcast episodes can be several GB. Same for Files app downloads. Open the Files app, check Downloads and On My iPhone, and delete old ZIPs, PDFs, video exports, GarageBand projects, voice memos, etc.
I agree with the others that Photos and Messages are usually the big ones, but I’d be a little cautious about relying only on iCloud optimization. It helps, but it does not instantly shrink everything, and it can be annoying if you travel or have bad signal because full-size photos may need to download later. If you want a cleaner break, copy older photos/videos to a computer or external drive, verify they open there, then delete them from the phone and empty Recently Deleted. That is different from just trusting sync.
For apps, “Offload App” is a good middle ground if you’re nervous. It removes the app but keeps its documents and data, so you can reinstall later. “Delete App” is more aggressive and can wipe local data. For bloated social/video apps, deleting and reinstalling is often fine. For art apps, music apps, file managers, games, password managers, or anything with local projects, check first.
External drives are useful, but only in a limited way. They can store photos, videos, documents, and exports. They do not make your 64 GB iPhone behave like a 256 GB iPhone because apps, iOS updates, app data, and most day-to-day storage still need internal space. If you keep hitting the wall after cleaning videos, downloads, messages, and unused apps, then the real answer is either pay for cloud storage, change what you keep locally, or buy a higher-capacity phone next time.
