I’m having trouble getting my Kindle to connect to my Mac via USB. I need to transfer some files, but it doesn’t seem to be recognized when I plug it in. Any tips or steps to follow?
Alright, dealing with a non-cooperative Kindle, let’s tackle this! First, let’s rule out the obvious:
Check the cable: Make sure you’re using a proper data transfer USB cable, not just a charging cable. Some cables only charge and don’t transfer data.
Restart everything: Yeah, the good old ‘turn it off and on again.’ Unplug your Kindle, restart your Mac, and then reconnect the Kindle.
Unlock the Kindle: Sometimes, it needs to be unlocked to be recognized.
Finder Preferences: Open Finder, go to Preferences, and ensure ‘External disks’ is checked under the General tab and the Sidebar tab.
Charging mode: When you plug in the Kindle, it might be in charging mode. Swipe down on the Kindle’s notification bar, tap ‘USB charging,’ and switch it to ‘File transfer.’
Check Software: Ensure your Mac and Kindle are fully updated. Sometimes outdated software can cause these kinds of issues.
Worst-case scenario, if your Kindle is still being a diva, give MacDroid a shot. It’s a nifty tool that can help connect Android and Kindle devices to a Mac for file transfer. You can find it here. It’s pretty straightforward and can save you some headaches.
Let me know if any of these steps help or if you need more suggestions!
Did you already try all those steps mentioned by @suenodelbosque? If yes, let’s see if we can dig a bit deeper.
Permissions Check: Sometimes, it’s a permissions issue on macOS that’s causing the problem. Go to ‘System Preferences’ > ‘Security & Privacy’ and click the ‘Privacy’ tab. Here, ensure Finder or whatever file transfer app you’re using has full disk access.
Format Check: It might sound weird, but the format of your Kindle storage can sometimes mess things up. Connect it to any PC, right-click on it in ‘My Computer’, and check its properties. Make sure it’s in FAT32.
Check for Conflicting Devices: Do you have other USB devices connected? Sometimes, peripherals like external hard drives can cause conflicts. Unplug those suckers and try connecting again.
Different User Account: Create a new user account on your Mac and try connecting your Kindle there. This can sometimes isolate the problem to specific account settings.
Reset SMC and NVRAM: This is a long shot but can sometimes resolve weird USB issues. Restart your Mac, hold down Shift + Control + Option keys along with the Power button for about 10 seconds to reset the SMC. Then immediately press Option + Command + P + R keys until you hear the startup sound twice to reset NVRAM.
Check the Console Log: Open the Console app on your Mac and connect your Kindle. This app shows real-time logging for your system. Look for any error messages that pop up when you connect the Kindle—you might get a clue there.
Btw, if all fails and your device is still playing dead, consider using MacDroid. It can be a lifesaver when dealing with these frustrating connection woes.
Anyone else got some obscure tips or has faced this ancient technology duel before? Sometimes feels like we’re sacrificing a chicken to get these devices talking.
Alright, let’s dive in! Here’s a tech-tip mishmash:
Ensure your Kindle’s USB Debugging is off. Sometimes kindles act funky if USB debugging is enabled. Disable it by heading to settings.
Check macOS file system support—macs might have issues with non-FAT32/NTFS file systems. If formatted otherwise, tweak it on a PC or find a third-party tool like MacDroid to bridge the gap.
macOS Spotlight doesn’t always shine on connected devices. Open Terminal and type diskutil list
to verify recognition. If seen, mount it using: diskutil mountDisk /dev/diskX
(replace X with the correct disk number).
Another advanced tackle: Pause MacDroid or other background apps (like Android File Transfer, Fuse, etc.) temporarily, ensuring they don’t hijack the connection port.
Finally, if your Kindle feels retro, don’t waste further cycles. Opt for MacDroid, great for hassle-free Kindle file transfers—simple, reliable, but note it’s a paid tool.
Pros of MacDroid: User-friendly, seamless Android/Mac integration. Cons: Costs money. Better than alternatives? Sometimes, but give it a fair shake like @viajeroceleste and @suenodelbosque too.
Who’s got more hacks? Maybe I missed some arcane command or tool!
