My iPhone has become really slow and laggy, and I can’t figure out why. I’ve tried restarting it, clearing storage, updating iOS, closing apps, and checking battery health, but nothing seems to help. Apps take forever to open and even typing feels delayed. What else could be causing this iPhone performance issue?
If your iPhone suddenly feels awful at simple stuff like typing, the first thing I’d check is storage. Not just whether you have a little space left, but whether you have enough space for iOS to work normally.
About that “keep 1GB free” advice
The 1GB thing is real, but it is more of a bare-minimum safety line than a performance target. Apple recommends having at least 1GB free to avoid serious problems like crashes or boot loops. For the phone to actually feel normal, you usually want something closer to 10 to 20 percent of the total storage free.
When storage is almost full, iOS has very little room for temporary files, cache, and virtual memory. So even basic actions like typing, scrolling, or launching an app can turn into the phone constantly moving data around in a cramped space. Restarting might make it feel better for a minute, but it does not solve the storage problem.
Deleting one or two random apps usually does not make much difference either. Most of the time, the real storage hog is Photos: old 4K videos, screen recordings, burst shots, and a ton of almost-duplicate pictures that built up over years.
Manually sorting through all of that is a pain. Clever Cleaner is useful for this because it is free, has no ads or subscription, and focuses on the stuff that usually eats the most space.
The quickest way to get real storage back is usually this:
- Start with the Heavies tab. It sorts files from largest to smallest and shows the exact size, so huge 4K videos and forgotten screen recordings are easy to spot. Deleting just a few of those can free up several GB.
- Then check the Similars tab. It groups near-duplicate photos and chooses a Best Shot from each set, which is much faster than comparing ten nearly identical pictures yourself.
- After deleting things, open Photos, go to Albums, then Recently Deleted, and tap Delete All. This part matters. Files in Recently Deleted still count against your storage for 30 days, so your phone may stay slow if you skip it.
Clever Cleaner does its processing on the device, so your photos are not uploaded somewhere else.
A few settings worth checking too
Go to Settings, then General, then Background App Refresh, and turn it off. Background refresh can keep apps using resources even when you are not actively using them.
For Safari, go to Settings, then Safari, then Clear History and Website Data. Safari cache can pile up separately from everything else.
Also check whether Low Power Mode is always on. It saves battery by limiting performance, so if you leave it enabled all the time, lag during normal use is not surprising.
If freeing storage does not fix it
Look at Settings, then Battery, then Battery Health. If maximum capacity is under 80 percent, Apple’s performance management can slow the phone down to prevent unexpected shutdowns. At that point, a battery replacement is the real fix.
One exception: if this started right after an iOS update, especially within the last couple of days, the phone may still be reindexing in the background. Plug it in, leave it on Wi-Fi overnight, and give it two or three days before deciding something is actually wrong.
A phone that is slow only inside a few apps is a different case from a phone that stutters everywhere, including the keyboard, lock screen, and Settings. If it is system-wide and you already checked storage/battery like @mikeappsreviewer mentioned, I’d stop closing apps over and over and try Reset All Settings before doing a full wipe. It won’t delete your photos or apps, but it can clear out weird network, keyboard, display, VPN, and accessibility settings that sometimes make the phone feel broken. After that, watch whether it heats up while doing nothing. If it does, something is running hard in the background and the lag may be throttling, not “old phone” slowness.
Make an encrypted backup first, then do a clean test before restoring your stuff. If Reset All Settings does nothing, the next useful split is figuring out whether the phone itself is slow or your current setup is slow.
Erase the phone, set it up as new for a short test, and don’t restore the backup yet. Install one or two normal apps, try typing, opening Settings, scrolling Safari, taking a photo, etc. If it’s still laggy while basically empty, you’re probably looking at hardware, heat/throttling, a bad battery reading, or some iOS issue that needs Apple diagnostics. If it suddenly feels normal, then restoring your backup may bring the problem back, which points to some app, setting, VPN/profile, keyboard, widget, or background sync mess rather than the iPhone being “old.”
I agree with @vrijheidsvogel that Reset All Settings is a good lower-risk step before this. I’d just be careful with the storage-cleaner angle after a point. Freeing space matters a lot, and something like Clever Cleaner can be handy for finding giant videos/photos, but if you already have plenty of free storage, deleting more stuff probably won’t fix system-wide stutter. At that stage, the clean setup test saves you from guessing forever.
