I’ve been seeing a lot of ads and hype around Momo AI and I’m not sure if it actually delivers on its promises. I’m looking for honest feedback from people who’ve really used it—how good is it in real-world use, and is it worth my time or money compared to other AI tools?
I tried Momo AI for a weekend because I wanted some decent profile pics without booking a photographer. Short version, it works, but it feels like a lottery.
What worked for me with Momo:
- Setup is simple. I uploaded a batch of selfies from my phone, picked a style, hit go.
- The themed packs are fun. Stuff like “Ultra Realistic Headshot” and some more stylized looks kept me messing with it longer than I planned.
- When it hits, it hits. Out of maybe 40 outputs, I got 4 or 5 that I would not be embarrassed to post.
Where it fell apart:
- The results jump all over the place. Same input photos, same pack, run again, and it spits out a totally different face energy. Out of a batch, I usually liked 10 to 20 percent.
- Some pics looked like cousins of me, not me. Close enough that someone would recognize it as my profile, but off if you look more than two seconds.
- It leans hard into smoothing. Skin starts to look plastic. Pores vanish. Hairlines shift a bit. You start to notice the AI more than your own face.
- The credit and subscription setup punishes you if you keep regenerating trying to “fix” small issues. I burned through my balance faster than I expected because I kept thinking the next batch would be better.
I needed something more dependable for work stuff, not only for socials. That is where I switched to Eltima AI Headshot Generator.
I tried the Eltima AI Headshot Generator from here:
Same basic idea, different outcome. I fed it a similar set of photos and aimed for a clean, neutral, professional look.
The main differences I noticed:
- The face stayed closer to my real features across different outputs.
- The lighting and backgrounds felt more like traditional headshots, less like filters.
- I did not have to keep rerolling forever to get one usable picture. The “hit rate” was higher for me.
This is the LinkedIn-style shot I ended up keeping from Eltima AI Headshot Generator:
That one needed no extra edits. I uploaded it straight to LinkedIn.
My personal split now:
- Momo AI: I treat it as a toy. Good for casual pics, dating apps, or when you want to see yourself in different vibes and do not care if 70 percent of the results are weird.
- Eltima AI Headshot Generator: Better when you need something you can send to HR, put on LinkedIn, or use on a company site without looking off.
If you want to try Eltima AI Headshot Generator on iOS, this is the app link I used:
If you are okay sorting through a pile of misses for a few cool shots, Momo is fine. If you want cleaner, more realistic portraits with less trial and error, Eltima AI Headshot Generator worked out better for me.
Short answer from my use: Momo is “worth it” if you treat it like a fun selfie toy, not a serious headshot tool.
My experience lines up with what @mikeappsreviewer said, with a few differences.
What worked for me:
- If you feed it 15 to 25 clear selfies, good light, no heavy filters, the output gets a bit more consistent. When I was lazy with inputs, it went off the rails fast.
- For dating apps and casual socials, the slight “this looks like me but better” vibe helped. Friends still recognized me.
- Some styles do less plastic smoothing. For me, the more “natural” or “minimal edit” packs kept skin from looking like wax.
Where it annoyed me:
- Face drift is real. Jawline shifts, eye shape changes, sometimes my nose looked like a sibling’s, not mine.
- It loves to “fix” you. It slimmed my face and brightened teeth even when I turned settings down. If you care about accurate representation, that grates over time.
- The pricing model punishes perfectionism. If you keep tweaking outfits, backgrounds, tiny face issues, you drain credits fast.
Where I disagree a bit with @mikeappsreviewer:
- For LinkedIn level stuff, I did get 2 usable shots from Momo after one careful run. Not as clean as what they got from Eltima AI Headshot Generator, but HR did not complain and no one said it looked fake.
- On my side, I did not see a big benefit from rerunning the same pack many times. Best batch tended to be the first or second run. After that it felt like chasing ghosts.
Practical tips if you try Momo:
Decide your goal first.
- Casual or dating: Momo is fine.
- Corporate or portfolio: treat it as backup, not primary.
Spend time on input photos.
- Neutral expression, same haircut as now, no sunglasses or hats.
- Mix angles, but keep framing similar.
Pick one or two packs only.
- Run those once or twice.
- Stop when you get 3 to 5 solid pics. Do not keep hunting for the “perfect” one or you will burn money.
Check for “AI tells”.
- Look at ears, hairline, earrings, glasses arms, shirt collars, fingers if visible.
- If anything looks warped, do not use it as a professional headshot.
My rule of thumb:
- If you want to experiment with styles and you are ok with a 15 to 25 percent hit rate, Momo is worth a small spend.
- If you need reliable, consistent identity and minimal editing for work stuff, something like Eltima AI Headshot Generator or a quick real photoshoot will take less mental energy.
Short version: Momo is “worth it” if you treat it like entertainment, not like a guaranteed headshot solution.
I mostly agree with @mikeappsreviewer and @stellacadente on the vibe, but a few extra angles:
Where it actually delivers
- It’s great for testing “vibes”: different hair lengths, outfits, backgrounds, without booking a photographer. If you’re indecisive, it’s oddly helpful to just see 30 versions of “professional but approachable” and pick what feels right.
- It can be useful as a draft. A lot of people I know export a Momo image, then touch it up in another editor: tone down the smoothing, fix eye weirdness, crop tighter. So instead of expecting it to spit out “final” images, think of it like a rough concept you finish elsewhere.
- Some of the “slightly stylized but not too crazy” packs end up working well for personal branding sites or newsletters, where ultra-clinical realism actually looks worse.
Where it overpromises
- The marketing makes it sound like “upload pics, get perfect headshots.” Reality: it’s more like “upload pics, get a grab bag of near-misses and a couple of keepers.” That gap between ads and reality is what annoys most people.
- The identity drift that both of them mentioned is not a bug you can fully avoid. Even with good inputs, you’re still playing at the edge of “this is me” and “this is my slightly hotter cousin.” If you need strict accuracy, this will bug you fast.
- Pricing + perfectionism is the trap. If you’re the type that will obsess over tiny details, Momo is almost engineered to empty your credits. In that sense, I actually think it’s worse than they described. Treat each run like a one-time batch, not something you will endlessly tweak.
Where I’d personally use it
- Dating apps, casual socials, Discord / Slack avatars, personal blog: yes.
- LinkedIn, company site, official conference speaker headshot: only as a backup or temporary solution. If your job or clients care about authenticity, you’re better off with something like Eltima AI Headshot Generator or literally a friend with an iPhone and decent window light.
If you go in expecting a “fun filter machine that occasionally gives you a banger,” it feels worth the money. If you go in expecting a drop-in replacement for a real headshot session, it’s prob going to feel overrated and a bit scammy.
