Halfway through making a short sequence, Kling AI Video Generator started changing the main character’s face and clothing between clips. I reused the same prompt and reference image, but the results still do not match. Is there a reliable way to keep character details consistent across separate generations?
Generate the mini-character sheet ahead of time before generating more clips: front view, three-quarter view, profile, and full-body, all in the exact hairstyle and outfit. If your Kling workspace has Elements or a “Bind Subject” tool, create the character there using several images or a short multi-angle shot rather than reference photo. This gives the model more visual information to bind to.
For each new shot, use the last clean frame of the previous clip as the start image and bind the same character Element. Keep the model, aspect ratio, visual style, and seed consistent should those options be available. Avoid rewording the character description. Instead, describe the action and camera directions, leaving their appearance described to the references.
There is still no absolute continuity between independent generations. Drastic differences in lighting, angle, expression, or clothing will result in more drift. For an essential animation, generate it as one long multi-shot clip and cut it afterward or make cuts in the middle of fast movements or use reaction shots to mask minor discontinuities.
Regenerate only the first bad clip, before proceeding; later ones will continue to inherit it. Alignment of the crop and lighting of the previous ending frame usually more important than repeating the same text prompt.
The prompt is not a character lock, kling will re-imagine the same description and reference image on every generation, if the character turns around, changes expression, or is shrunken to fit in the picture.
@crypto_cloud_wolf is right that a bad ending frame can contaminate the next clip, but I would avoid chaining every shot from the previous output. Create a clean “master” still of the character instead, then use that same image as the reference for each new shot. Keep hair, clothing, camera distance, and lighting nearly identical until the sequence is stable. Add motion afterward rather than asking for a new pose, outfit, location, and camera move in a single clip.
For an established sequence, the fastest solution is usually to cut before the inflection and use a reaction shot, close-up of some object, or even a brief rear view in between to hide minor continuity problems, rather than trying to use up precious credits by attempting to generate every possible frame of a given moment.
A close-up, which results in a different face, is often an identity-reference problem. Whereas a wide shot, which keeps the overall face but changes the clothes, is most often a composition problem. Kling is possibly paying less attention to the detail in clothing if the character takes up a smaller part of the screen than in the prompt/source image, despite an identical prompt and source image.
I would do a deliberately boring test before investing more credits into the sequence. Use the clean reference, fixed camera, neutral lighting, little movement, and same framing as the successful clips, and see if the character is still changing. If so, recreate or re-upload the reference setup because the current binding is most likely faulty. If the test works, the tough shot is asking for too many changes at once, so reduce the camera move, body rotation, background activity, or expression until you find what provokes the drift.
I would be cautious about treating a master still as a universal reference, too. @vladthedebugger’s approach makes sense for similar shots, but a front-facing portrait may provide poor guidance for a distant side view. For those shots, create a matching reference from the same established character rather than forcing Kling to infer the unseen clothing, hair, and facial structure. A face crop can protect identity, while a separate full-body image can carry the outfit, if your generation mode accepts more than one reference.
See also the action words. Some models will read “gets ready to leave” or “steps into the rain” or “enters the party” as an invitation to don a coat, accessories, makeup, or more formality. Specify continuity requirements: same shirt, same jacket, same hairdo, no changing of the wardrobe. Then describe only the movement that needs to occur. Negative instructions are not a guarantee, but can eliminate accidental garment reveals.
I would regenerate from the first failure as @zeroshift5667 suggests, but only after isolating the cause. Otherwise you may get a better face by chance and hit the same problem again two clips later. For shots that require a major angle or scale change, an intermediate clip with a smaller transition can be safer than jumping directly from close-up to full-body profile. It costs another generation, but it gives Kling less missing visual information to invent.
Whether the failed clip is continuation of the previous action or separate image-to-video generation makes a difference in diagnostics, as in the former case, Kling is likely to carry the altered face from one segment to another via motion history, while in the latter, the software prioritizes the reference as guidance rather than identity. Both issues might present themselves in a similar manner, but their underlying mechanism differs, which makes the correction process different as well.
In my case, I would pause the video generation and attempt to fix the faulty keyframe as a separate still. The image should be edited in such a way that the character occupies the same visual space as instructed, with the same pose, facing the same direction with the same expression, and wearing the same clothes. Once the keyframe is corrected, the issue might resolve itself when the motion is reapplied, as the reference now hosts the desired appearance without ambiguity. If it proves too difficult to achieve in a single keyframe, the attempt at video generation is bound to fail and become a waste of resources. However, once the correct keyframe is identified, it should be used as the starting point for motion, possibly with the motion request narrowed down to specify the exact transformation.
While instructing the software to utilize the same prompt as before seems logical, in practice, it is too vague a statement for Kling to actually follow. Ideally, the prompt used for the initial clip should be massaged into a new prompt that defines the same character appearance and scenario, but without reference to the previous output. In reality, the same prompt often fails to produce the same result, especially if the description was ambiguous or partially adopted from the reference. In cases when both the prompt and the reference image contain the same errors, Kling will attempt to synthesise a combination of both, which rarely yields satisfactory results. Thus, I would advise to trim the appearance-related part of the prompt rather than add extra continuity-related instructions. Let the image define the character for the most part, while the prompt should specify the action, framing, and what should not happen in the generated media.
@bluefalcon9284’s neutral test is useful, but I would compare the first generated frame before judging the whole clip. If frame one is already wrong, the motion is irrelevant and you can cancel that direction immediately. If frame one matches and the identity breaks during a turn, occlusion, or fast camera move, then the shot itself is exceeding what the reference can support. That calls for a simpler movement path or a manually prepared frame from the difficult angle.
I would not re-create every successful clip to get an exact consistency. Instead, take a small set of “approved” face and outfit frames from the existing media, and use their closest equivalent for every angle. For the first failed attempt, make the correct starting image from the approved set and continue the generation from that point. For a short media clip, it might be faster to fix a couple of the generated images in post-production than to ask Kling to relearn the appearance of the same character from scratch. The generator may be able to produce continuity between takes, but I would treat that as a feature requiring manual control rather than an inherent characteristic of the repeated prompt.
The seed advice is the one I would take with a grain of salt. Having the seed fixed allows the repetition of the same result if everything else is the same, but changing any other parameter (framing, pose, camera) will result in having a different face with the same seed. People tend to use it as a lock, and then wonder why it slips.
What nobody’s mentioned is the reference image quality itself. If your master still is soft, low res, or the character sits small in the frame, Kling has less to bind to and starts guessing on close-ups. Crop tight, keep it sharp, and make the face actually readable before you blame the motion. @nanolynx5324’s point about fixing the keyframe as a still first is the real time saver here. Get one clean frame you trust, then animate from that, instead of burning credits hoping the video pass sorts the identity out for you.
Create your sequence using one approved clip.
Add your best clip to your editor. Split your clip into 2 or 3 parts. Make sure one part is full width, one is cropped and add an environment shot between them. Ensure they’re in order so it makes sense.
As the footage has been approved you will have the same face and costume. It won’t give any new actions or angles but is an easier way around creating a short sequence without using up your credits on more failed attempts.
