Need help sending long videos on iPhone
Been having trouble sending long videos from my iPhone. Every time I try, the video either gets compressed or doesn’t send at all. I need to share some important footage with a friend for a project. How can I send full-length videos without losing quality?
Oh man, sending long videos from an iPhone is always a bit tricky. First off, make sure you’re connected to strong Wi-Fi, cuz cellular data might not cut it for big files. If you’re trying to use iMessage and it compresses the video, that’s because there’s a size limit.
To send full-length videos without losing quality, consider using cloud services like iCloud, Google Drive, or Dropbox. Just upload the video to one of these services and then share the link with your friend. Here’s how to do it with iCloud:
  1. Open the Photos app.
  2. Find the video you want to share.
  3. Tap the Share button (the box with an arrow pointing up).
  4. Select ‘Copy iCloud Link’. It might take a few seconds to prepare the link.
  5. Send the link to your friend via text, email, etc.
They can then download the video in its full quality. If you’re going Google Drive or Dropbox route, the steps are pretty similar: upload the video to the respective app and share the link. Problem solved.
If you’re doing this frequently and looking for another alternative, you might want to try sending videos through a platform designed for larger files, like WeTransfer. You don’t have to compress the videos, and you can send up to 2GB for free.
Remember, it’s all about leveraging these platforms to bypass the built-in limitations of iMessage or email.
So just wrap it up: cloud storage or file transfer service is your best bet here to avoid compression. Keep your videos crisp, no more headaches from failed sends.
Yeah, those built-in sharing options can be frustrating. Another approach you might consider is using AirDrop if your friend is in close proximity and also has an Apple device. AirDrop ensures you can transfer videos without compression, provided both of you are on iOS devices or Macs.
Here’s how you can do it:
  1. Ensure both devices are on Wi-Fi and Bluetooth.
  2. Activate AirDrop on both devices (Settings > General > AirDrop).
  3. Open the Photos app and select the video you want to share.
  4. Tap the Share button and select your friend’s device under AirDrop.
AirDrop is fast and maintains the quality of your video, avoiding the hassle of uploading to the cloud.
For remote sharing, you could try a different angle with apps like WhatsApp or Telegram. They also have size limits but are way easier for quick sharing compared to dealing with file transfer services. Telegram, for instance, supports files up to 2GB, which is pretty nifty.
In instances where the footage needs to be edited collaboratively, consider a video editing platform like Adobe Premiere Rush. Upload the video to a shared project, and your friend can access the full-quality footage for editing.
Lastly, always double-check file formats. Sometimes converting the video to a slightly different format, like from MOV to MP4, can alleviate some of these sending issues without compromising quality.
Remember, diversifying your sharing methods depending on the situation can save a ton of time and stress. Cell data’s not your friend here, try sticking to Wi-Fi or even tethering if your Wi-Fi’s flakey.
Consider Signal too - it offers great encryption and also has a more generous file size limit compared to iMessage. Mix and match these strategies, and soon sharing long videos won’t be the nightmare it currently feels like. Cheers!
Sounds like you’ve got a real tough task there. Agreeing with @stellacadente and @cazadordeestrellas, a strong Wi-Fi is key when sending long videos from an iPhone. But let’s talk about another cool trick: using a file compression app.
There are apps like WinZip or RAR for iOS that can compress your video into a ZIP or RAR file. This reduces the file size without losing quality. Then, you can use an app like WeTransfer to send the compressed file. Here’s how you can try that:
  1. Download WinZip or a similar app from the App Store.
  2. Open the app and navigate to your video.
  3. Compress the video into a ZIP file.
  4. Share the compressed file through WeTransfer.
This way, you tackle the size issue directly. The downside is your friend will need to decompress the file at their end, but honestly, it’s a minor inconvenience compared to getting a pixelated video.
Airdrop is great but if your friend isn’t nearby or on an Apple device, you’re stuck. In cases like these, you might want to consider another app like Send Anywhere. This app supports files up to 10GB for free, which is a big win if your video is particularly massive.
  • Convenient for large files
  • No quality loss
  • Requires the recipient to have the app
  • Not always as fast as other methods
I’ve also seen Telegram and WhatsApp mentioned. While Telegram supports up to 2GB, WhatsApp is much lower, so I wouldn’t rely on WhatsApp for long videos. Signal is more secure, mostly, but still comes with its size limitations.
Another method might be to share through a dedicated media server like Plex. You set it up at your place, upload your video, and share the Plex link with your friend. Plex handles pretty large files nicely, though it requires initial setup.
For very frequent needs, investing in a good cloud storage service like Google Drive or Dropbox is the most streamlined approach, as noted by @stellacadente and @cazadordeestrellas. It works seamlessly for most collaborative work.
Diversifying your process is key. Using different tools for local and remote sharing helps reduce frustration. Next time this happens, you’ll know exactly which route to take. Hope this sheds some light on your problem!
Use Mail Drop. Open Photos, select the video, tap Share, then Mail. Add your friend’s email and send. When prompted, choose Mail Drop. It supports files up to 5 GB and keeps them available for 30 days. Your freind downloads the original file through a link, with no extra app or ZIP steps.
Zipping a video barely shrinks it, so the WinZip step @chasseurdetoiles mentioned mostly just adds a decompress chore for your friend without saving real space. Video files are already compressed. If you want zero quality loss and no extra apps, Mail Drop is the simplest path here, just make sure your friend grabs it before the 30 day window closes.
