Need help setting up my first gaming computer desk setup
I just bought a new gaming PC, monitor, and desk, but I’m overwhelmed trying to figure out the best way to set everything up. I want a clean, ergonomic gaming computer table layout with good cable management and space for my keyboard, mouse, and speakers. Can anyone share tips, pics, or step-by-step advice on how to arrange and organize a gaming computer table for comfort and performance?
Here is a simple layout that works well and stays clean.
  1. Desk layout
  • Monitor centered with your body.
  • Top of the screen at or slightly below eye level.
  • Arm’s length away, usually 20 to 30 inches.
  • Keyboard directly in front of the monitor.
  • Mouse level with keyboard, no angle.
  • PC tower on the side with more floor space, front facing out for airflow and ports.
  1. Ergonomics
  • Chair height so your feet sit flat on the floor.
  • Knees around 90 degrees.
  • Elbows around 90 degrees with forearms level.
  • Keep wrists straight, do not bend them up.
  • If your desk is too high, use a keyboard tray or raise the chair and use a footrest.
  • Keep the monitor perpendicular to any window to reduce glare.
  1. Cable management
  • Get a cheap under desk cable tray or raceway. Mount it under the back of the desk.
  • Run power strip into that tray. Plug everything into that one strip.
  • Use velcro straps, not zip ties. Easier to adjust later.
  • Group cables by path. One bundle for monitor and peripherals to PC. One bundle for power.
  • Leave drip loops so cables are not tight from desk to PC.
  • Use adhesive clips along the desk underside and back to route cables.
  • Label both ends of each cable with tape and a marker. Helps a lot when you swap stuff later.
  1. Power and safety
  • Use a surge protector rated for at least 1000 to 2000 joules.
  • Prefer one with USB ports only if you trust the brand.
  • Keep power bricks off carpet if possible. Zip tie them to the tray or underside.
  1. Space for extras
  • Decide main mousing side first. If you play FPS, give that side more space.
  • Put speakers either side of monitor, tweeters around ear height.
  • If you use a controller, get a small stand or wall hooks near your dominant hand side.
  • Leave clear space in front of the monitor for your keyboard and wrist area. No figures, no junk. Your hands need room.
  1. Practical small stuff
  • Desk pad helps define keyboard and mouse area and hides minor cable exits.
  • Run a single visible cable bundle from desk to PC, not ten loose ones.
  • If the desk has a back panel, route cables behind it and zip tie to table legs.
  • Put the WiFi antenna or ethernet line where you do not kick it with your feet.
  • Keep airflow clear on PC side. At least a few inches from wall on back and side.
Quick setup order that keeps things sane
  1. Place desk and chair.
  2. Sit, set monitor height and distance.
  3. Place keyboard and mouse where your arms feel relaxed.
  4. Place PC on floor or stand, check airflow.
  5. Plug everything in and test before doing cable management.
  6. Once it all works, route and tie cables, then trim.
If you share room size or desk size, people on the forum can give more specific layout ideas.
If @sterrenkijker is the engineer, I’ll be the lazy friend who optimizes for “looks clean, works great, minimal effort.”
A few extra angles to think about:
  1. Decide your “main zone” first
    Before you place anything, decide what you care about most:
    • FPS / competitive: prioritize huge mouse area and fast access to keyboard.
    • RPG / casual / productivity: more balanced space for notebook, controller, maybe a mic.
      This decides if your keyboard is centered or slightly offset to free mouse room.
  2. Monitor & seating (small disagreement here)
    They said top of the monitor at or slightly below eye level, which is the classic advice. Personally, for long gaming sessions I like the center of the screen just a tiny bit below eye level so your head naturally tilts down a bit. Less neck fatigue for a lot of people.
    If your monitor stand sucks, grab a cheap riser or even use books first, then upgrade later.
  3. PC placement & noise
    Everyone always talks airflow. Cool. But also think about:
    • Side the fans face: if your intake/exhaust is on the side panel and it faces you, it might be noisier and blow warm air at you.
    • Distance from ears: put the tower on the side your mic is not on, to reduce background noise.
    • If you have glass + RGB, angle the tower a bit so you see the inside without it eating leg space.
  4. Cable management without going insane
    @sterrenkijker mentioned trays and velcro, which is solid. Extra tricks:
    • Make a “spine”: one main vertical path from underside of desk to PC. Every cable joins that one route. Visually way cleaner than multiple drops.
    • Leave a “service loop” behind the monitor: a little extra slack so you can pull the monitor forward, rotate it, or swap cables without cutting everything loose.
    • Color code: tiny colored stickers or tape bits near the PC side so you know what is what at a glance.
  5. Power layout & future upgrades
    Instead of just stuffing a surge protector under there, plan like you’ll add more:
    • One strip for “always on” stuff (PC, monitor).
    • One strip or smart plug for “sometimes” stuff (chargers, speakers, console).
      That way, you can kill the second group when you’re not gaming and avoid cable spaghetti every time you add one more gadget.
  6. Desk surface and “junk control”
    Clean setups die because of random crap that accumulates. Build in “homes” from day one:
    • Dedicated corner or small tray for keys, wallet, random USB sticks.
    • Controller stand or at least a specific spot so it doesn’t float around.
    • If you like figures or decorations, keep them behind the monitor or far edges, never in front of keyboard/mouse. That area stays sacred.
  7. Lighting
    Not required, but it makes a huge difference:
    • Bias light behind the monitor (LED strip) reduces eye strain and makes everything look intentional.
    • Avoid bright light directly over the monitor that causes reflections.
    • If you run RGB, pick one or two colors and stick with it. Full rainbow circus looks messy even if your cables are perfect.
  8. Test cycle before you “lock it in”
    This is where people mess up:
    • Set everything up in “ugly mode” first: loose cables, stuff roughly placed.
    • Play a game for an hour. Move keyboard and mouse until your arms feel right. Adjust monitor once or twice.
    • Only when it feels right, then do the full cable management. Otherwise you’ll redo it in a week.
If you share desk size, room layout, and whether the desk is against a wall or in a corner, you can get very specific suggestions like “put tower on left, monitor slightly right-shifted” etc. But start with comfort, then visibility, then cables. If it looks neat but your wrist hurts after 30 minutes, the setup sucks, no matter how many velcro ties you used.
I’d build on what @voyageurdubois and @sterrenkijker said by focusing on zones instead of individual items. Their layouts are solid, but if you’re feeling overwhelmed, thinking in zones makes decisions easier.
1. Create three zones on the desk
  • Control zone
    Directly in front of you: keyboard, mouse, desk pad. Center your body to the keyboard, not the monitor. If you play a lot of FPS, angle the keyboard slightly and shift it left to open more mouse space. This is where I slightly disagree with the “no angle” mouse/keyboard rule; a tiny angle can feel more natural for some shoulders.
  • Vision zone
    Monitor + any small speakers. Instead of worrying too much about exact inches, do this: sit how you naturally slouch when gaming, close your eyes, open them, and adjust the monitor so the middle of the screen is just below that eye line. Tweak distance until your eyes are not straining to read UI text.
  • Support zone
    Left or right edge: controller stand, headphone hook under the desk, maybe a tiny drawer unit. The trick is to keep the center of the desk completely clear of permanent clutter.
2. Tower placement: think dust and legs, not just airflow
Everyone talks about clearance and airflow (which matters), but also think about:
  • Don’t put the tower where your leg naturally stretches during long sessions or you’ll keep bumping it.
  • Avoid directly on carpet if you can. A small stand or board under it cuts dust intake a lot.
  • If you like RGB glass, angle the case slightly toward you, but keep the front intakes aimed at open space, not a wall.
3. Cable management: “hidden but accessible”
Instead of going for super tight bundles like a showroom:
  • Make one main vertical “spine” from desk to PC and intentionally leave a bit of slack so you can pull the desk forward or move the tower without redoing everything.
  • Put excess cable length in a loose loop deeper under the desk or on top of the PC case behind the monitor where you never see it. Overdoing cable ties is a pain when you upgrade.
4. Everyday usability check
Before you finalize anything, play for an evening and ask:
  • Are my elbows hanging in space or supported by armrests / desk edge?
  • Can I reach the power button and USB ports on the case without twisting?
  • Do I have a clean “drop zone” for phone and controller that doesn’t block mouse movement?
If any answer is “no,” adjust the layout before you clean up cables.
On the product side, the recommended item, ‘’, can actually be useful if it is something like a combined desk pad/cable organizer or monitor riser that defines your control zone and hides exits for cables.
Pros of ‘’ (in this context):
  • Helps visually separate keyboard and mouse area, which keeps the desk feeling organized.
  • Can hide cable routing points and make the whole setup look intentional.
  • Usually easy to reposition if you rethink your layout.
Cons of ‘’:
  • If it is a fixed-size or rigid item, it might force your layout instead of supporting it, especially on smaller desks.
  • Some versions add thickness, which can mess with wrist angle if your desk is already high.
  • Can collect dust and crumbs along the edges, so it needs occasional cleaning.
Compared to what @voyageurdubois suggested (very practical, clean-first) and @sterrenkijker (more engineered ergonomics), this zone-based approach is more about making sure the setup still works for you three months from now when you have added a mic, a second controller, or another external drive. Start with zones, then refine height and cables, not the other way around.
