Need help setting up my new AirPods correctly
I just bought a pair of AirPods and I’m struggling to get them set up and connected properly to my iPhone and other Apple devices. They don’t always show up in Bluetooth settings, and sometimes only one AirPod works. Can someone walk me through the right setup steps and any common fixes so they pair and sync the way they’re supposed to?
This sounds like a pairing / sync mess, not hardware dying yet. I’d go step by step and “reset” the whole AirPods setup across your devices.
  1. Check basics
    • Charge case with cable for at least 15–20 minutes.
    • Put both AirPods in the case, lid closed, for 5–10 minutes.
    • On your iPhone, turn Bluetooth off, wait 5 seconds, turn it back on.
  2. Remove old pairings everywhere
    On each Apple device where you ever used them:
    • iPhone / iPad: Settings > Bluetooth > tap the “i” next to your AirPods > Forget This Device.
    • Mac: System Settings > Bluetooth > click the “i” or right click your AirPods > Forget.
    Do this on all devices, not only the phone. Old pairings sometimes confuse auto switching.
  3. Hard reset the AirPods
    This fixes the “only one side works” issue a lot.
    • Put both AirPods in the case.
    • Close lid for 30 seconds.
    • Open lid, leave AirPods in.
    • On iPhone: Settings > Bluetooth, keep this screen open.
    • On the case, hold the setup button on the back about 15 seconds until the light turns amber, then goes white.
    Release when it flashes white. That means full reset.
  4. Pair again with iPhone first
    • Keep lid open, hold the case next to iPhone.
    • Wait for the popup. Tap Connect.
    If no popup, go to Settings > Bluetooth and look for them under “Other Devices”. Tap the name to connect.
  5. Fix “only one AirPod works”
    If one side still cuts out or does not play:
    • Check battery levels. On the iPhone Home Screen, swipe right to the Widgets screen and use the Batteries widget. If one AirPod shows 0% often, that is a known issue with one side not charging correctly.
    • Take both out, play music, then put only the silent one back in the case for 10 seconds, then put it in your ear again. This forces a re‑sync.
    • Settings > Accessibility > AirPods > check that “Automatic Ear Detection” is on.
    • Also check Settings > Accessibility > Audio/Visual > Balance. Make sure the slider is in the center, not stuck to left or right.
  6. Turn off auto switching for now
    If you own a Mac or iPad, auto switching sometimes makes them disappear.
    On each device:
    • Go to Bluetooth > click/tap the “i” next to the AirPods.
    • For “Connect to This iPhone / Mac”, pick “When Last Connected to This iPhone / Mac”, not “Automatically”.
    This keeps the connection more stable while you sort this out.
  7. Try a “clean” test
    Once paired to iPhone and stable:
    • Play music or a podcast for 5–10 minutes with phone near you.
    • Then lock the screen and leave it alone, see if both sides stay active.
    If this works, then try connecting to your other Apple device again. Add them back one device at a time.
  8. If they still disappear from Bluetooth
    • Reset network settings on iPhone: Settings > General > Transfer or Reset iPhone > Reset > Reset Network Settings. Note this wipes Wi‑Fi passwords, so you need them again.
    • After restart, repeat the pairing process from step 3.
  9. When it is probably hardware
    From user reports and Apple docs, typical hardware signs:
    • One AirPod never charges above a few percent.
    • The case LED never goes white during reset.
    • You hear distortion or crackling even when close to the phone.
    If you see this, run the Apple Support app, choose AirPods, run their test, then book a repair or replacement. If they are new, Apple usually swaps defective units fast.
Do the full forget + reset + re‑pair process once, in this order, before trying random toggles. It saves time and avoids half‑fixed behavior where one side works sometimes and then dies again.
What @stellacadente wrote is solid for the “nuke it from orbit and reset everything” approach. I’d tweak the strategy a bit so you’re not constantly wiping pairings if the problem is actually something simpler.
Here’s what I’d try on top of (or instead of immediately) doing the full reset:
  1. Confirm they’re actually new to iCloud
    If you bought them used or someone else paired them first, they might still be tied to another iCloud account.
    • On your iPhone: Settings > your name > Find My > Devices.
    • If the AirPods show up there under some weird name you didn’t choose, that can mess with pairing and auto‑switching.
      In that case, you really do need the full reset + re‑pair on your own Apple ID.
  2. Check for “ghost” Bluetooth conflicts
    Sometimes it’s not the AirPods, it’s other devices hogging Bluetooth.
    • Turn off or move away from nearby Bluetooth stuff: speakers, car head units, game controllers, random earbuds.
    • On your iPhone, in Bluetooth, tap “i” next to old headphones you never use and “Forget This Device.”
      This reduces the chaos so your AirPods actually show up consistently.
  3. When they don’t appear in Bluetooth
    Instead of constantly forgetting and resetting:
    • Open the case with AirPods inside, hold it right next to the top of the iPhone.
    • Wait 10–15 seconds.
      If the card doesn’t pop up, quickly toggle Airplane Mode on, wait 5 seconds, then off again.
      I’ve had AirPods suddenly appear 2 seconds after doing that, with no full reset needed.
  4. Only one AirPod working: check the physical fit in the case
    This part gets overlooked a lot:
    • Take out the “dead” AirPod, blow gently into the case slot and on the metal contacts, then re-seat it.
    • Wiggle it a bit and make sure the LED does a little blink when you close the lid.
      Lint or a slightly misaligned earbud can make one side look paired but never actually charge or sync.
  5. Turn off a couple “smart” features while testing
    I slightly disagree with leaning only on resets. Sometimes the smarter features are the problem:
    • On iPhone: Settings > Bluetooth > AirPods “i”
      • Turn off “Automatic Ear Detection” temporarily.
      • Set Microphone to “Always Left” or “Always Right” instead of “Automatically Switch AirPods.”
        This helps figure out if iOS is just switching all audio responsibility to one side.
  6. Check for audio routing weirdness
    When just one bud works or they randomly disconnect:
    • While playing music, open Control Center.
    • Tap the little AirPlay icon (triangle with circles).
    • Make sure your AirPods are selected, not iPhone or some TV in the next room.
      Sometimes it looks like they dropped but iOS just shoved audio somewhere else.
  7. Test them totally away from other Apple gear
    If you own multiple Apple devices, they can fight over the AirPods even with auto‑switching tuned down:
    • Turn off Bluetooth on your Mac and iPad completely.
    • Walk to a different room with just your iPhone and the AirPods.
    • Open the case, connect, and listen for 10–15 minutes.
      If things are suddenly perfect, the issue is your multi‑device environment, not the buds themselves.
  8. Quick firmware sanity check
    You can’t force‑update firmware, but you can make sure it has a chance:
    • Plug the case into power.
    • Leave it near your iPhone, connected to Wi‑Fi, for at least 30 minutes.
      Some early firmware versions had more pairing bugs than later ones.
  9. Early hardware screening trick
    Before you bother with repeated resets:
    • Put both in your ears, play something.
    • Lightly push and twist each AirPod in your ear.
    • Move your jaw a bit, turn your head.
      If you hear crackling from one side or it cuts in/out when you move, that’s very often a driver or connection issue inside the bud, not a software glitch.
If after cleaning contacts, testing away from other devices, and disabling some of the “smart” features you still have:
  • one bud constantly showing a way lower battery, or
  • random dropouts with the phone right next to you,
then I’d jump to what @stellacadente said about Apple Support. New AirPods should behave a lot more boring than this.
