Need help understanding how Zocks Ai actually works
I just started using Zocks Ai and I’m confused about what it really does and how to get useful results from it. The docs feel vague, and I’m not sure which features I should focus on first or how to set it up for my specific use case. Could someone explain the main capabilities, ideal workflows, and any setup tips or best practices so I don’t waste time using it the wrong way?
Yeah, the Zocks docs are… not exactly hand‑holding material.
Think of Zocks AI as a “spec-aware brain” that sits on top of your code + tasks, not a magic button that just finishes your project. It’s mostly about 3 core things:
  1. Context / Knowledge setup
    This is the part people skip and then wonder why the answers suck.
    Focus on:
    • Uploading or linking your specs (requirements, design docs, API contracts, tickets)
    • Pointing it at the right repo / folders
    • Defining any constraints: coding style, stack, dos/don’ts
    If Zocks has no real context, it just guesses. If you front‑load good context, it suddenly looks “smart.”
  2. Task types you should start with
    Don’t start with “build the whole app.” Use it like a powered assistant, not a replacement dev. Try:
    • “Explain this spec in plain English and list open questions”
    • “Summarize this module and how it connects to the spec”
    • “Generate test cases based on this spec”
    • “Spot inconsistencies between this spec and this file”
    You basically want it to be your spec interpreter + sanity checker first, before code monkey.
  3. How to get useful results (prompting, basically)
    Be annoyingly explicit:
    • Tell it what you want: “I want a step‑by‑step implementation plan, not code yet.”
    • Give format: “Return as a checklist with priority labels P1/P2/P3.”
    • Scope it: “Only consider files in src/feature-x and this spec doc.”
    Example of a good first use:
    “Here’s our feature spec. Here’s the repo path.
    1. List all components that need to change
    2. Map each spec bullet to specific files
    3. Call out any missing details in the spec that would block implementation.”
  4. Features to ignore at first
    Depending on how they packaged it, I’d delay playing with:
    • Auto‑refactor across the whole repo
    • Any click‑once codegen that promises “end to end”
    • Fancy workflow automations
      Until you trust how it reasons about your actual spec.
  5. Basic setup order that usually works
    Rough sequence that keeps you sane:
    1. Connect repo / workspace
    2. Upload or link your main spec(s)
    3. Ask it to summarize the spec and tell you what it thinks the main modules / flows are
    4. Ask it to tie the spec to existing code
    5. Only then ask for plans, stubs, tests, or refactors
If you share how you’re using your spec (backend API, frontend feature, QA plan, etc.), people here can probably suggest concrete prompts that fit your setup. Right now you’re probably just underfeeding it context and overexpecting magic.
I’ll push slightly in a different direction than @kakeru here.
What Zocks is really doing under the hood is juggling 3 things at once:
  1. what’s in your spec/docs,
  2. what’s in the repo it can see,
  3. whatever task you just asked it to do.
Instead of thinking “spec‑aware brain,” think “very forgetful senior dev that only knows what’s currently on their desk.” It does not remember your whole project unless you deliberately wire that in every time or via workspace/project config.
Concrete stuff that usually confuses people:
  1. Zocks is session‑sensitive
    • If you ask it something huge like “implement the whole spec,” it will silently drop context once it exceeds its context window.
    • To avoid that, break work into small, boring chunks:
      • “Only reason about this specific feature section and these 3 files.”
      • “Only generate tests for this endpoint.”
    • If answers start getting vague or off, assume it lost some context and re‑pin the spec + paths.
  2. Spec setup is not “set & forget”
    Slight disagreement with how simple it sounded: just uploading a spec once is not magic.
    • Zocks often needs you to explicitly re-attach the spec or workspace doc:
      • “Use spec-v3.md as primary source of truth.”
      • “Ignore older spec files like spec-v1.md and spec-v2-archive.md.”
    • If you have multiple specs (PRDs, API docs, tickets), tell it which one wins when they conflict.
  3. It’s better as a reviewer than as a generator at first
    Instead of asking it to write code or tests from scratch early on, try “reverse‑pressure” tasks:
    • Paste code you wrote and ask:
      • “Compare this implementation to section 3.2 of the spec and list all mismatches.”
    • Give it test cases and ask:
      • “Which spec requirements are not covered by any of these tests?”
        You get higher signal, less hallucinated structure.
  4. Use it to build a living spec, not just read one
    Where Zocks starts to be actually useful is when you let it evolve your spec, not just obey it:
    • “Given the current spec and this existing code, propose a cleaned‑up, single source of truth spec.”
    • “Normalize these 4 contradictory tickets into one coherent requirement doc.”
      Then you copy‑edit what it produces and re‑upload that as the new main spec.
      The loop becomes: messy inputs → Zocks draft → human fix → upload cleaned spec → better future answers.
  5. Guardrails that save you from pain later
    Add a short “rules” block and reuse it in multiple chats:
    • Tech stack it must respect.
    • Things it must not do (e.g. “Do not introduce new dependencies without explicitly justifying them”).
    • Level of detail you expect.
      Basically your house style. Paste that into new convos until you figure out how to make it persistent in your workspace.
  6. What to actually try in the first 1–2 hours
    Instead of feature tours, I’d do this small experiment loop:
    • Take one feature section from your spec.
    • Ask: “Extract all explicit requirements as a numbered list, each ≤1 sentence.”
    • Then: “For each requirement, which file(s) in src/... are most relevant and why?”
    • Then on a single file: “List behaviors implemented here that are not mentioned anywhere in the spec.”
      If those three prompts give you on‑point answers, your setup is good enough.
      If not, you probably need to trim what it can see or clarify which docs matter.
  7. When it starts lying
    Zocks will occasionally bluff instead of admitting “I don’t know.” Treat that as a feature of LLMs, not a bug in your project. To fight it:
    • Add: “If information is missing from the spec or code, explicitly say ‘UNKNOWN’ and ask me a question instead of guessing.”
    • Then watch how many UNKNOWNs you get. If it’s a lot, your spec is the problem, not the tool.
If you describe what your spec is for (e.g. backend API vs frontend flows vs QA scenarios), ppl can throw you some more targeted prompt templates. Right now your confusion is pretty normal: Zocks will look “vague” until you aggressively tell it what to ignore and where to look.
Short version: Zocks AI only feels “vague” if you let it stay abstract. Treat it like a configurable toolchain, not a chat bot.
1. What Zocks AI actually is (in practical terms)
Ignore the marketing. Functionally, Zocks AI is:
  • A retrieval layer over:
    • your specs / docs
    • your repo
    • sometimes tickets or tasks
  • Plugged into an LLM that:
    • reads that context
    • runs some “task templates” (compare, summarize, generate, refactor)
    • returns structured output
So it is less “intelligent teammate” and more “very fast analyst that needs guardrails every time.”
Where I slightly disagree with @nachtschatten and @kakeru: they frame it mostly as “spec interpreter / reviewer.” That is the safest starting point, yes, but you can get decent lightweight generation out of it early if you constrain it properly.
2. First features to actually click and use
Instead of roaming around the UI, pick 2 or 3 features and ignore the rest for a bit:
a) Spec ↔ Code mapping / navigation
Use Zocks AI to answer only this question at first:
“Given this spec section, what parts of the repo matter?”
Why this matters:
  • Forces you to wire spec + repo correctly
  • Immediately shows whether Zocks is seeing the right files
  • Gives you a mental map of your own project
If the answers are hand‑wavy, fix sources before blaming the model:
  • Trim which folders Zocks can see for that workspace
  • Remove stale or legacy specs from its scope
  • Mark a single doc as “canonical” and tell it so in the prompt
b) Scoped generation, not freeform codegen
Use Zocks AI to produce one artifact at a time, very tightly scoped:
  • A single test file
  • A single API handler stub
  • A migration plan for one module
Prompt pattern that works well:
“Use spec-v3.md only. Target: src/payments/checkout.
Generate just a draft of the handler function signatures and inline TODO comments, no full implementations.”
If it goes off the rails, you know context or scoping is wrong, not the whole system.
c) Change impact analysis
This is underused:
“According to spec-v3.md, if we change requirement X, which files and tests are most likely affected?”
Great for:
  • Understanding blast radius
  • Planning refactors
  • Sanity checking product decisions
3. How to configure Zocks AI for your spec work
Think of setup as three knobs you must tune:
  1. Visibility
    • Limit which folders are indexed for a given project (e.g. only src, tests, docs/current).
    • Exclude noise: old POCs, experiments, archived docs.
  2. Authority
    • Decide a hierarchy:
      • spec-v3.md > tickets > code comments > everything else.”
    • Tell Zocks AI this explicitly:
      “If spec-v3.md conflicts with tickets, prefer spec-v3.md and flag the conflict instead of ‘fixing’ it.”
  3. Behavior
    • Set “house rules” in a reusable block:
      • Tech stack & versions
      • No new deps without justification
      • Prefer diffs / patches over full file rewrites
      • Ask questions instead of guessing when data is missing
Reuse that block whenever you start a new chat / task until you figure out persistent config.
4. Where I’d not use Zocks AI at the beginning
Here I’m slightly harsher than the others:
  • Not for:
    • Designing entire architectures
    • Writing complex multi‑service flows alone
    • Massive repo‑wide refactors
Not because it cannot help, but because:
  • Context windows are finite
  • Spec contradictions are common
  • It will confidently “fill in the gaps” if you let it
Use it as an accelerator on work you already roughly understand, not as a planner for things you have zero model of.
5. Concrete workflows you can try right now
Pick one of these and run it end to end.
Workflow A: Spec hygiene loop
  1. Give Zocks AI all your related spec docs for one feature (PRD, API doc, old notes).
  2. Ask:
    “Produce a single, normalized spec. Keep only what you can justify from these docs. Mark unclear or conflicting items explicitly.”
  3. Manually edit that output into a clean spec.
  4. Reupload that as spec-vX-clean.md.
  5. From now on, always reference that file by name in prompts.
This makes every later answer better because the source of truth is less chaotic.
Workflow B: Implementation guidance, not code
  1. Attach your clean spec + repo.
  2. Ask:
    “Give me an ordered list of implementation steps for this feature, each step small enough to be 1–2 PRs, with the key files per step.”
  3. Challenge its plan:
    • Remove unnecessary steps
    • Add missing migrations / testing
  4. Only then ask for:
    “Generate a checklist of test cases for steps 1–3.”
You stay in control of architecture and sequencing. Zocks stays in its lane.
Workflow C: Regression risk before a change
Before a big refactor:
  1. Tell Zocks AI:
    “We plan to change X behavior in src/foo. Using the current spec and code, list all observable behaviors that might regress, grouped by user-facing vs internal.”
  2. From that list, derive:
    • What to manually test
    • What new automated tests to add
This uses it as a thinking aid, not a code factory.
6. Pros & cons of using Zocks AI for spec‑driven work
Pros
  • Very good at:
    • Surfacing inconsistencies between spec and code
    • Turning messy docs into one coherent spec
    • Quickly mapping “what in the repo does this requirement touch”
  • Can save a lot of time on:
    • Test case ideation
    • Impact analysis
    • Spec summarization for new teammates
Cons
  • Needs deliberate setup:
    • If you skip context curation, you get generic fluff
  • Finite context:
    • Big monorepos or huge specs can cause silent information loss
  • Hallucinates when:
    • Specs are incomplete and you do not explicitly tell it to say “I don’t know”
7. How it compares to what @nachtschatten and @kakeru said
  • I agree with @nachtschatten on using Zocks as a “forgetful senior dev” that only knows what is on its desk. This is a healthy mental model.
  • I agree with @kakeru on starting with explanation / review tasks, but I would not wait too long before trying tightly scoped generation. You learn faster by bouncing between:
    • “Explain / critique”
    • “Draft something small”
    • “Compare draft to spec”
If you share whether your spec is mostly backend APIs, frontend UX flows, or QA requirements, you can tailor these workflows and prompts to that domain and actually see Zocks AI earn its keep.
