Need Help With Female Attorney Headshots
I need advice on female attorney headshots for a law firm profile and LinkedIn. I recently had photos taken, but they look too stiff and don’t feel professional or approachable enough for my practice area. I’m trying to figure out what poses, wardrobe, and photographer direction work best so I can retake them and make a stronger first impression.
I had to sort this out for a law profile update not long ago, and the two apps I kept coming back to were Eltima and Photoleap. If your goal is female attorney headshots for LinkedIn, a firm bio, or a website profile, I’d start here:
Eltima AI Headshot Generator — best for professional legal-style portraits
Eltima felt simpler to me. It runs on iPhone, so I uploaded photos straight from my camera roll and didn’t need to move files to a laptop or mess with extra steps. For a quick professional result, that mattered.
Why I’d put Eltima first for attorney headshots:
It stays easy on mobile, from upload to final image.
The business and professional templates fit law firm profile photos better than flashy social styles.
The output tends to look polished, plain, and corporate in a good way.
It fits the usual places you need this stuff, LinkedIn, firm staff pages, lawyer directories.
For legal bios, the small details matter more than people think. Neutral background. Good lighting. Expression that looks confident without feeling stiff. Eltima seems built for that lane.
Photoleap is the one I’d check next if you want to edit more instead of taking the first clean result.
Photoleap also works on iPhone, but the feel is different. It leans more into editing, with AI tools layered in, so I found it better when I wanted to keep adjusting things instead of accepting one default look.
What stood out to me in Photoleap:
It has an AI headshot tool where you upload a photo and pick a career-oriented style.
You get several polished business looks, including corporate-style options.
You’re able to change background, lighting, and smaller visual details after generation.
It all happens on mobile, so there’s no need to switch to desktop.
The main reason people pick it, I think, is control. If your first image is close but not there yet, Photoleap gives you room to keep pushing it.
If your priority looks like this:
fast setup
clean legal-profile styling
low effort
then Eltima makes more sense.
changing the background
adjusting lighting
cleaning up details
trying a few different business looks
then Photoleap is the better fit.
My own take is pretty simple. I’d use Eltima AI first for the standard polished attorney photo. If the result felt close but I wanted more control over the finish, I’d move to Photoleap and edit from there.
I’d push this in a diff direction than @mikeappsreviewer.
If the photos already exist, fix the source choices first before using any app. Most stiff attorney headshots come from 4 things. Chin pushed back. Tight smile. Shoulders squared to camera. Eyes too wide.
For women on law firm pages, the strongest shots usually have:
slight body turn, around 20 to 30 degrees
chin forward and down a touch
relaxed mouth, small smile
camera at eye level or a hair above
plain backdrop, gray, soft white, muted navy
Crop matters too. LinkedIn works best with head and upper torso. Firm bio pages often look better chest-up. If the frame is too tight, you look tense. If it’s too loose, it looks casual.
I’d retouch lightly. Fix flyaways, under-eye shadow, shine. Don’t over-smooth skin. People notice, and it reads fake fast.
If your practice area is family, estate, employment, mediation, show more warmth. If it’s litigation or corporate, keep more structure. Same person, diff expresion.
If none of the shots have the right expression, I’d re-do one short session with a photographer who shoots lawyers often. Ten solid minutes beats hours of bad selects.
I’d split the difference between @mikeappsreviewer and @nachtdromer, but honestly I disagree a little with both if the core issue is “too stiff.” That’s usually not a retouching problem first. It’s a selection problem.
A lot of attorney headshots fail because people pick the one that looks the most formal instead of the one that looks the most believable. For law firm bios, “approachable + competent” usually beats “perfect posture + serious face.” LinkedIn especially punishes overly rigid photos becuase they read like old corporate directory pics.
What I’d do:
  1. Ignore your favorite outfit for a second and review only expression.
  2. Pick shots where one eye is slightly softer, smile is not fully forced, and jaw looks relaxed.
  3. Avoid the image where you look “powerful” if it also makes you look annoyed.
  4. Ask 3 people in your field which photo feels most like someone they’d actually call.
Also, women attorney headshots tend to look better when styling is simplified more than people expect. Less jewelry, cleaner lapel line, hair either clearly framed or clearly tucked. The in-between messy-professional thing photographs weirdly.
One thing I kinda disagree with: not every legal headshot needs the standard gray backdrop. If your practice is family law, estate planning, mediation, plaintiff-side work, a warmer neutral can feel more human and still professional.
If none of the current shots feel right, don’t spend forever “saving” them. A 15-minute reshoot with a better brief can fix this fast. Sometimes the first session just wasn’t aimed at your actual brand, and that’s ok.
