Need Help With SD Card Video Recovery, Where Should I Start?
I need help with SD card video recovery after some important videos suddenly disappeared from my camera memory card. I’m not sure if they were deleted, corrupted, or lost during transfer, and I want to avoid making things worse. What steps should I take first to recover lost video files safely?
I lost a clip once and the first thing I wanted to know was simple, is it gone for good?
A lot of the time, no.
When a video gets deleted, the footage usually does not vanish on the spot. What disappears first is the card’s record of where the file lives. The raw data often sits there until new files land on top of it. So the first few minutes matter more than people think, and one bad move can shrink your odds fast.
1. Stop using the card
The second you notice the video is missing, quit using the memory card.
Do not shoot more video. Do not snap photos. Do not format it because some menu told you to. I’ve seen people do all three in a panic, then wonder why recovery pulled back broken clips.
Take the card out of the camera, drone, dashcam, whatever you used. Put it aside. Leave it alone until you’re ready to recover data from it.
2. Figure out if software is enough
Some cases are fine for a home recovery attempt. Some are not. I would split it like this.
Software recovery makes sense when
  1. You deleted the files by mistake.
  2. The card got formatted.
  3. The card shows up as RAW.
  4. Your camera reports a file system error.
  5. The videos disappeared even though the card still reads.
Skip DIY and look at a recovery service when
  1. The card is cracked, bent, or looks physically damaged.
  2. Your computer does not detect the card at all.
  3. The card keeps dropping connection.
  4. The device reports hardware failure.
  5. The footage matters enough where you do not want to risk extra damage.
If the card has physical damage, repeated scans and reconnects are not a good idea. I would not keep poking at it.
3. Make an image of the card first
This is the step people skip, then regret later.
Before you run recovery, make a full disk image of the memory card. You end up with a copy of the card exactly as it sits right now. If the recovery attempt goes sideways, you still have the original state saved somewhere else.
This is how a lot of recovery techs work. They deal with the copy, not the original card over and over again. Less risk. Better habit.
4. Recover the video with Disk Drill
Photo recovery is usually less messy. Video is where things get ugly.
Many cameras, drones, dashcams, and action cams save footage in fragments instead of one neat chunk. A basic recovery app might find pieces of the file but fail to put them back together in a way your player accepts.
I’ve had better luck with tools built for camera footage, and Disk Drill gets mentioned a lot for this because of its Advanced Camera Recovery mode. It is meant for fragmented video reconstruction from supported memory cards and cameras. It checks pieces of footage and tries to rebuild the original file layout instead of treating the video like one uninterrupted block. That helps with clips from GoPro, DJI, Sony, Canon, Nikon, Fujifilm, Insta360, and similar gear.
If you want to try it, do this:
  1. Plug the original memory card into your computer with a card reader.
  2. Open Disk Drill.
  3. Pick the memory card from the list.
  4. Choose Advanced Camera Recovery.
  5. Start the scan.
  6. Wait. Some scans take a bit.
  7. Preview what it finds.
  8. Save recovered videos to a different drive.
Do not restore files back onto the same card. I did this wrong once years ago. Bad idea. Save them somewhere else.
5. Open the recovered videos and test them
Recovery is not done when the files show up in a folder.
Open a few of them. Scrub through. Play the middle, not only the first few seconds. A file might look normal at first and still be corrupted halfway through. I learned this one the annoying way.
If a recovered clip refuses to play, try VLC Media Player first. If the damage is worse, a dedicated video repair tool might help clean it up enough to make the footage usable again.
First, check whether the files are missing or the folder view is lying to you. I’ve seen cameras write clips into weird DCIM subfolders, and Windows Finder-style browsing misses them after a bad transfer. Turn on hidden files on your computer and look for .MP4, .MOV, .MTS, or .LRV files before you do anything else.
I agree with @mikeappsreviewer on stopping use of the card. I don’t fully agree on jumping straight into a full image first if you’re not comfortable with disk tools. For a lot of people, the safer first move is a read-only scan with a decent recovery app, then copy results to your PC. Less fumbling, less chance you press the wrong thing.
A quick triage list:
  1. Card reads fine, files missing, DIY recovery is worth trying.
  2. Card asks to format, still detected, DIY is still worth trying.
  3. Card disconnects, gets hot, or is not detected, stop. Service lab.
  4. Videos copied over once, then vanished from PC, check the destination drive too.
For video work, Disk Drill is a solid place to start, esp if the clips came from a camera or drone and the files look incomplete. Use preview where possible, and recover to another drive. Then test file size. A 0 KB or tiny clip is a bad sign. A normal size clip with playback issues often means corruption, not full loss.
Also, check this if you want a plain roundup on SD card video and photo recovery options:
top SD card recovery software for deleted videos and photos
One more thing people skip. Look at the card’s free space. If your missing videos total 12 GB and the card suddenly shows 12 GB free, deletion is likely. If space is still used, the files are often hidden, corrupted, or the file table is messed up. Small detail, but it helps narrow it down fast.
Don’t format it yet, even if the camera keeps nagging you. That part trips up a lotta people.
I’d add one thing neither @mikeappsreviewer nor @voyageurdubois really stressed enough: verify whether this is actually an SD card problem or a transfer problem first.
If the videos vanished after copying to your computer, check:
  • the PC recycle bin
  • the destination drive with file search by extension
  • your video editor’s import/cache folder
  • whether the files became zero-byte during transfer
A lot of “SD card recovery” cases are really incomplete copy jobs. Seen that more than once, annoyngly.
Also, I slightly disagree with the idea that everyone should start with deeper recovery modes right away. If the card still mounts normally, first do a plain file-level check with a tool like Disk Drill and see if the original folder structure is still there. If it is, that usually tells you more than a raw carve does. Raw recovery can dump back nameless video chunks and make a mess.
What I’d do in order:
  1. Lock the SD card if it has a physical write-protect switch.
  2. Test it in a different card reader, not just a different USB port.
  3. Search manually for hidden or odd video files.
  4. Check used/free space on the card.
  5. Run a non-destructive scan with Disk Drill.
  6. Recover only to your computer or another external drive.
  7. If recovered clips exist but won’t open, then look at video repair tools.
If the card is unstable, slow, disappears randomly, or asks to format every time, stop messing with it. That’s where DIY gets risky fast.
For anyone researching this kind of mess, this thread is pretty on point: how to recover lost video from a corrupted SD card.
Main thing: don’t run CHKDSK, don’t format, and don’t put the card back in the camera to “see if it comes back.” That move bites people a lot.
One angle I’d add to what @voyageurdubois, @espritlibre, and @mikeappsreviewer said: check whether the camera still sees thumbnails or clip counts. If the camera shows clips but the computer does not, that often points to a reader, transfer, or filesystem interpretation issue, not true deletion.
I also wouldn’t always trust the camera’s built-in playback as proof the files are safe. Some cameras can show cached thumbnails even when the actual video file is damaged.
What I’d check first:
  • card label and capacity match what you expect
  • write speed / age of card if this happened during long recording
  • whether the last clip was interrupted by battery loss or forced shutdown
  • if the missing files are only the newest ones, which often means directory damage rather than full card failure
On software, Disk Drill is reasonable for a first pass.
  • easy interface
  • good with common SD card file loss cases
  • can preview some recoverable files
  • useful when you want a quick scan without messing with command-line tools
  • not magic for physically failing cards
  • deep scans can return messy, renamed files
  • large video recovery can take a while
  • full recovery features are paid
My slight disagreement with the “scan immediately” camp: if the card is behaving strangely but still readable, sometimes just mounting it repeatedly is already too much. If it clicks, drops, freezes Explorer, or stalls reads, stop and escalate.
Also, if recovered videos are present but unplayable, compare their size to what your camera normally produces per minute. That tells you a lot faster than guessing. A 20-second 4K clip that comes back as 3 MB is usually toast or incomplete.
