Need tips for safely mounting a TV on my living room wall
I just bought a new flat screen TV and want to mount it on my living room wall, but I’ve never installed a wall mount before and I’m nervous about damaging the wall or having the TV fall. The wall is drywall over studs in an older house, and I’m not sure what kind of mount, anchors, or tools I actually need, or how to find the studs correctly. Can anyone walk me through the safest way to mount the TV and what to watch out for so I don’t mess this up?
Drywall over studs is perfect for a TV mount if you hit the studs and use the right hardware. Step by step.
  1. Check TV and mount specs
  • Look at TV weight in the manual or on the box.
  • Check the mount rating. It must be higher than the TV weight.
  • For a 55–65 inch TV you often see 30–60 lb. Many decent mounts are rated 100+ lb for safety.
  1. Get the right tools
  • Stud finder (good one, not the $5 toy)
  • Level
  • Drill
  • Drill bits: small pilot bit and one that matches the lag bolt size in the kit
  • Socket wrench or good screwdriver
  • Tape measure
  • Pencil
    Optional but helpful
  • Painter’s tape to mark studs
  • Friend to hold the TV
  1. Find the studs, twice
  • Run the stud finder horizontally across the wall.
  • Mark each edge of the stud with light pencil lines.
  • The stud center is between those two lines.
  • Move up or down a bit and check again to confirm.
  • Studs are usually 16 inches on center in the US. Measure 16 inches to find the next one and confirm with the finder.
Do not trust one single beep. Double check. A lot of failed mounts came from screws in drywall only.
  1. Decide height before drilling
  • Sit where you watch TV.
  • Eye level from the main seat usually sits around 36–42 inches from floor.
  • Many people mount the center of the TV at eye level or a bit higher.
  • Measure TV height, divide by 2, then use that to mark where the center should go on the wall.
Example
  • TV height 28 inches, half is 14.
  • You want center at 40 inches.
  • Mark 40 inches from floor on wall. That is TV center line.
  1. Mark the wall plate holes
  • Hold the wall plate on the wall, centered on your TV center mark.
  • Make sure at least two vertical mounting slots line up over studs. Three studs is even better for big sets.
  • Use a level on top of the plate.
  • Mark the lag bolt holes that fall in the studs.
Double check level here. A crooked TV annoys you every day.
  1. Pre drill into studs
  • Use a drill bit a little smaller than the lag bolt diameter. Example: 5/32 inch pilot for a 5/16 lag, check your kit instructions.
  • Drill straight into the stud. You should feel solid resistance the entire way.
  • If the bit suddenly loses resistance you left the stud. Stop and fix the mark.
  1. Mount the wall plate
  • Place the plate back on the wall.
  • Drive the lag bolts through plate holes into the pilot holes.
  • Tighten until snug and firm. Do not over tighten so hard that the plate bends into the drywall.
  • Re check with the level once all bolts are in.
If the mount kit came with small wood screws instead of proper lags for studs, throw those out and get 5/16 lag bolts from the hardware store.
  1. Attach brackets to the TV
  • Lay the TV face down on a soft surface like a blanket.
  • Line up the vertical brackets with the VESA holes on the back.
  • Use only the screws that fit easily and sit flush. Do not force longer screws, they damage the panel.
  • Tighten them snug, not gorilla tight.
If the screws bottom out before they tighten, add the included spacers.
  1. Hang the TV
  • Use two people.
  • Lift the TV and hook the brackets onto the wall plate.
  • Make sure you hear or feel the latch engage, some designs use safety bars or pull strings.
  • Engage all safety locks the mount has.
  1. Check tilt and tension
  • Adjust tilt angle. Tighten the side knobs.
  • Gently push and pull to make sure nothing shifts or feels loose.
  • Step back, check level. Many mounts let you micro adjust a bit.
  1. Cable management and strain relief
  • Plug in HDMI and power before you push the TV flat if it sits close to the wall.
  • Use right angle HDMI or power plugs if clearance is tight.
  • Add a small cable clip or zip tie to the mount to support cable weight so connectors on the TV do not carry all the force.
Common traps to avoid
  • Using drywall anchors instead of studs for a large TV. Bad idea.
  • Trusting only a magnet and guessing where the stud is. Use a stud finder plus measurement.
  • Mounting only to one stud with a narrow plate. Use a wider plate that spans at least two studs.
  • Ignoring the weight rating of the mount. Cheap mystery mounts from random sellers sometimes have weak steel or poor welds.
If your studs are not where you want the TV
  • Use a wider mount that spans across the available studs.
  • Or screw a horizontal 2x8 board across two or three studs, then mount the TV bracket to that board. Paint the board to match the wall for looks.
For reference, a single 5/16 lag bolt into a stud holds well over 100 lb in shear in most home walls. A typical mount uses four. Your TV will not fall if you hit studs, use proper lags, and lock the brackets.
Couple of extra angles to think about that @jeff didn’t really lean on:
  1. Test the wall before committing
    • Lightly push your knee into the drywall between two studs. If it flexes a lot or feels crumbly, you might be in an older house or a bad patch. In that case, spread the load more: longer plate, or a 2x8 ledger board screwed into multiple studs, then mount to that.
    • If the wall feels “drummy” in one area, check there is not a plumbing stack or HVAC chase behind it. A stud finder with AC detection helps, but I also like to poke a tiny nail behind the TV area just to feel what’s back there before drilling big holes.
  2. Ignore the “bare minimum” stud count
    • Yeah, two studs is usually fine. Personally I try for three whenever the mount allows it, especially on 65’+ TVs. You’re not just fighting weight, you’re fighting leverage when someone tugs on the corner or a kid bumps it.
    • If your mount only hits one stud nicely and the other holes fall in drywall, I’d honestly return that mount instead of trying to get clever with anchors.
  3. Use decent lag hardware, not whatever mystery metal came in the box
    • Where I slightly disagree with @jeff: I don’t always trust the kit lags just because they’re lags. Some are cheap pot metal with shallow threads. I usually buy 5/16 x 2.5 or 3 inch structural lags (Spax, GRK, etc.) and use those into studs. Overkill? Yes. Regrets? None.
    • Use flat washers so the head does not chew into the mount slot.
  4. Plan for future cable changes
    • Don’t mount the TV so close to the wall that you have to unhook it every time you add a new HDMI device.
    • A simple trick: temporarily tape the biggest connector you own (like a chunky HDMI) to the back of the TV where the ports are and measure how much clearance you need. That way the arm / tilt angle is set with reality in mind, not just “flush looks cool.”
    • If you think you might ever hide cables in the wall, now is the moment to rough in a recessed box or at least cut a low-voltage opening. Way easier now than later.
  5. Find the center, then cheat it visually if needed
    • The actual wall center and “looks right from the couch” center are not always the same. Before drilling, put painter’s tape where you think it should go, sit down, and stare at it for a bit.
    • If the stud layout forces the plate a couple inches off center, often you can still shift the TV left/right on the plate to visually center it. Check the mount’s lateral adjustment range before you buy.
  6. Check the TV’s back panel before you trust the screws
    • Some TVs have really shallow VESA inserts. Do not assume “longer is safer.” If a screw is even slightly too long, it can crack the panel internally.
    • Thread a screw in by hand first with no bracket. You should feel it bottom out gently before the head reaches the case. Then back it out and add the bracket and any spacers so that it tightens just as the head meets the bracket. If it binds early, wrong screw or wrong spacer combo.
  7. Do the “paranoid test”
    After the plate is up and before the TV goes on:
    • Grab the plate with both hands and pull like you’re trying to tear it off. Up, down, side to side.
    • If anything creaks, moves, or the drywall visibly compresses, address it now. When it feels like part of the house structure, then hang the TV.
      I’d rather slightly re-drill one hole than trust a mount that already complained during the stress test.
  8. Think about stud layout around the TV area
    • Sometimes the stud right where you want the center is actually a king stud or doubled stud around a window or opening, which is great for strength. If your stud finder suddenly shows a 3–4 inch wide “stud,” that might be what you hit. That’s actually a nice place to anchor.
    • On the flip side, if the spacing is weird (13, 19, 24 inches) you could be near a doorway or past a corner. In that case, measure from a known corner and map the pattern before trusting just the beeps.
  9. If something feels sketchy, stop
    • If your drill suddenly plunges with no resistance, you missed the stud. Do not try to “make it work” with anchors for a big TV. Patch the bad hole, move over, and redo it. Patching a few 3/16 holes is nothing compared to patching a ripped-out section of wall.
You’re already ahead of a lot of folks simply because you’re nervous about it. The people who scare me are the ones who slam toggle bolts into random drywall and then hang a 75 inch TV off them “because the box said 50 lbs.”
Skip the theory, here’s the extra stuff that actually makes or breaks a first‑time mount, on top of what @viajantedoceu and @jeff already laid out.
  1. Where beginners usually mess up
  • They trust the little cardboard “template” more than the actual metal wall plate. Templates can be off a few millimeters. For your first time, hold the real plate up, level it, and mark through the actual holes.
  • They don’t check what is behind the wall. Before drilling, kill the room lights, shine a flashlight at a shallow angle, and look for patched spots, old TV mount holes, or signs of a previous electrical or plumbing run. If your stud finder has AC detect, use it, but I also like a very small pilot hole (1/16) in the center area to confirm solid wood and not a pipe or duct.
  1. How high to mount, in practice
    Everyone talks eye level, but in real rooms:
  • If you have a low couch and sit close, follow the “center at eye level” rule.
  • If you have a more “living room with guests” setup, a bit higher actually feels better so people in the back can see. Aim for the bottom of the TV around chest level when standing.
  • If you pick a tilt mount, you can cheat the height higher and tilt it toward the couch so your neck is happy.
  1. Fixed vs tilt vs full motion
    This is where I slightly disagree with the “just get a basic mount” mindset. On drywall over studs, a decent full motion arm is totally fine if:
  • The mount is clearly rated above your TV weight
  • You actually hit the studs and use proper lag bolts
Full motion pros:
  • Super easy to reach ports, swap HDMI, run new devices
  • You can pull it out and point it at the dining table or kitchen
  • Bigger leverage on the wall, so two or three studs and real lag bolts are a must
  • Slightly more involved to keep it perfectly level when extended
Tilt mount pros:
  • Simpler, cheaper, lighter
  • Lets you hang the TV a bit higher and angle down
  • Still annoying if ports are tight on the back
  • Not great if you want to watch from multiple angles
  1. Cable planning that saves future pain
    Do this before you tighten everything down:
  • Mock up your cables with the TV on the floor. Plug everything in, then look at how far the connectors stick out.
  • If your TV ports are sideways, a low profile fixed mount is fine.
  • If your ports point straight back, use a tilt or a low‑profile arm so you are not smashing cables into the wall. Right‑angle HDMI and right‑angle IEC power cords are cheap insurance.
  • Leave one extra HDMI cable already plugged in and coiled behind the TV for “future device you forgot about.”
  1. Safety check that is not optional
    After the plate is lagged in:
  • Put your full body weight into a hard, sharp upward pull and a downward push on the plate. If anything feels spongy, flexes, or creaks, stop. That is a red flag on a stud miss, stripped pilot, or drywall crushing.
  • Look at the gap between plate and wall. You should not see the mount bowing the drywall in. If you do, you probably overtightened and are crushing the gypsum. Back the lags off slightly and recheck.
  1. When stud layout is wrong for your “perfect center”
    Instead of fighting it:
  • Use a wider plate that spans at least two studs and take advantage of the TV’s horizontal adjustment slots on the back. You can usually slide the TV left or right several inches.
  • If you are forced off center by a weird stud pattern, center the TV on the room visually, not the plate. Mark the visual center for the screen with tape, then work backward from the mount’s adjustment range.
  1. About using “generic” TV wall mounts
    A lot of people grab a no‑name flat screen TV wall mount because it is cheap and everywhere. That kind of basic mount can work fine if you respect its limits:
  • Usually very low profile so the TV sits close to the wall
  • Simple design, fewer moving parts to fail
  • Often compatible with a wide range of VESA patterns
  • Many of these kits include weak lag bolts and mystery hardware
  • Some plates are narrow and may only hit one stud, which is a dealbreaker for larger TVs
  • Instructions can be vague, especially on screw length and spacers for the back of the TV
If you use a generic flat screen TV wall mount, I highly suggest:
  • Upgrading the lag bolts to proper structural lags from the hardware store
  • Adding washers so the heads do not chew into the slots
  • Confirming your TV’s VESA pattern and ensuring the mount can slide enough to center it
  1. Comparing approaches
  • @jeff’s post is a rock solid “do this, then this” checklist. Follow that as your backbone process.
  • @viajantedoceu leans more into overbuilding and paranoia, which I actually like for big sets. I agree especially on stress testing and not trusting mystery metals, though I’m a bit more open to full motion mounts than they are, provided the hardware is upgraded and more studs are used.
Bottom line:
If you:
  • Hit at least two studs
  • Use real lag bolts
  • Stress test the plate before hanging the TV
    it is very hard to screw this up badly. Most disasters come from toggles in plain drywall or “close enough” stud guesses. Take your time on the stud finding and pilot holes and the rest is just careful assembly.
