What apps are similar to Dave?
I’m looking for apps similar to Dave because I need a payday advance option. I’ve used Dave before but would like to explore other alternatives. Can anyone suggest good options or share experiences with similar apps?
Yeah, there are a bunch of apps like Dave out there. Have you checked out Earnin? It’s kinda similar—you can get an advance on your paycheck without fees, but you “tip” whatever you think is fair. Another one is Brigit; it gives you cash advances up to like $250, plus it has tools for budgeting. There’s also MoneyLion—aside from payday advances, it offers more financial services like loans and credit building stuff. Oh, and don’t forget Chime! Though it’s more of an online banking system, with direct deposit you can access your paycheck a couple of days early.
But, seriously, these apps can add up if you’re constantly using them. If you’re just trying to get through one rough patch, cool. If it’s becoming a regular thing, maaaybe step back and think if there’s another way to fend off the next money crisis. Just a thought.
Earnin, Brigit, MoneyLion—yeah, those are solid options, as mentioned by @sternenwanderer, but lemme just say, they’re not always sunshine and rainbows. For one, Earnin’s whole ‘tip what you think is fair’ schtick can be tricky. Tips = fees, let’s be real. And Brigit? That $250 advance isn’t much if you’re in a bigger bind, plus there’s a monthly membership fee that sneaks up on ya. MoneyLion is cool if you want a broader range of services, but honestly, signing up for all the extras can feel overwhelming if all you wanted was a quick cash boost.
Another one you might wanna check out is Albert. They do cash advances too (up to $250), no interest, but it’s tied to their subscription for more personalized financial advice. Then there’s Floatme—small advances (like $50) but, hey, better than nothing. Plus, it’s cheaper than some other options.
Here’s the thing, though: payday advance apps kinda work like Band-Aids. Temporary fix, not a cure. If this is turning into a cycle (like, borrow-advance-repeat), maybe it’s time to talk with a nonprofit credit counselor or explore side gigs to bring in some extra cash flow. Just food for thought.
Sure, payday advance apps can be lifesavers, but like @stellacadente and @sternenwanderer said, they all come with their quirks. Since you’re checking alternatives to Dave, I’d second Albert—it’s solid for cash advances and ties into their smart budgeting tools (although the subscription might feel like extra baggage). Plus, FloatMe for smaller advances is a no-frills option if that works for you.
However, a wildcard app worth exploring is Varo. It’s a mobile banking service that offers fee-free overdraft protection (up to $50 or more, depending on your account activity). No “tips,” no interest—just clear terms, which some might find refreshing compared to apps like Earnin or Brigit.
On the downside, these apps often put you into an endless loop of short-term fixes. Instead of constantly juggling advances, consider apps like YNAB (You Need a Budget) for building better spending habits or even explore community lending platforms like Payday Alternative Loans (PALs) offered by some credit unions. Yes, PALs aren’t as instant, but they’re usually cheaper and can help break the cycle.
TL;DR: For alternatives, definitely check out Varo for easier banking integration, and don’t underestimate long-term budgeting tools like YNAB to get a handle on finances before payday stress becomes permanent chaos.
Skip new apps and set up a simple “payday buffer” with your current bank.
Next payday, move 20 to 40 dollars into a separate savings subaccount. Name it “Payday Gap.” Do this every paycheck, even if it hurts a bit.
Most people hit 100 to 200 dollars in a few months. That amount often replaces small advances.
Use that buffer only for true shortfalls before payday. Refill it first on payday.
This reduces fees, tips, and subscription costs over the year.
