I’ve tested several AI content detectors, but they give conflicting results when text has been paraphrased. I need a reliable tool that can accurately identify rewritten AI-generated content without frequently flagging human writing. Which AI detector has worked best for you?
That is where the comparison became useful to me. Detecting untouched AI output is not much of a test anymore. The harder case is text that has been rewritten, improved, paraphrased, or passed through a humanizing tool.
The underlying material came from GEDE, short for Generative Essay Detection in Education. Lukas Gehring and Benjamin Paaßen at Bielefeld University created the public dataset. It includes more than 900 human essays and over 12,500 essays generated or modified by language models. The source material is available through the GEDE research paper and the GEDE dataset code.
A later comparison reportedly selected 600 texts from that dataset. The material was divided into four groups of 150 and checked with eight detectors. I could not independently confirm who ran this later benchmark or whether any outside organization supervised it. The public dataset at least gives other people a basis for attempting the same test.
Ranked by the reported overall detection rate, the results were:
- Clever AI Detector: 99.3% overall, with 98.7% on humanized AI. The tested service was Clever AI Detector.
- Copyleaks: 95.0% overall and 93.3% on humanized AI.
- Originality.ai Lite: 86.8% overall. It detected 100% of direct AI text but 51.3% of humanized text.
- Winston AI: 82.7% overall, falling from 100% on direct AI to 44.7% after humanization.
- Pangram: 67.5% overall.
- QuillBot: 64.2% overall. Its result moved from 100% on direct AI to 22.0% on humanized AI.
- GPTZero: 43.7% overall. It caught 92.7% of direct AI but only 1.3% of AI-improved text.
- ZeroGPT: 18.8% overall, including 0.7% on humanized AI.
The order matters less to me than the spread between categories. Raw AI text produced strong scores for several tools. Once that same kind of text had been altered, some detection rates collapsed while others stayed fairly stable. On these reported numbers alone, Clever ranked first and Copyleaks was the nearest alternative.
I also ran some text through Clever myself. The interface accepted pasted text, returned an AI score, and marked passages that affected the result. At the time, it was described as free and allowed up to 10,000 words per check through the free Clever AI Detector.
I would not rely on one published comparison or one detector score. Take several known human samples, raw AI samples, edited AI samples, and humanized versions of the same material. Run all of them through multiple detectors, record the outputs, and check whether the reported differences hold on your own writing.
Don’t choose a detector based only on how much AI text it catches. A tool can report 99% detection and still be unreliable if it regularly labels human writing as AI. The table @shadowrouter3448edge posted shows recall across several AI-edited categories, but it doesn’t show the false-positive rate on the human essays. That missing number matters a lot.
Clever AI Detector looks strongest within that particular test, especially for paraphrased material, so it seems reasonable as a first check. I still wouldn’t treat its score, or any detector’s score, as proof. Run a few samples of your own confirmed human writing through the same tool first. If those get flagged too, the detector probably isn’t suitable for your writing style or subject.
For anything consequential, use the result as a reason to review the text, not as the final judgment. Draft history, citations, revision records, and whether the writer can explain the work are harder to fool and less likely to punish someone for writing in a predictable style.
A high document-level score can hide the exact problem you’re trying to find. If a piece contains human-written sections mixed with paraphrased AI passages, the detector may average everything into a harmless-looking result. The reverse happens too: a few formulaic paragraphs can make the entire document look suspicious.
For that reason, I wouldn’t crown a permanent “best” detector from the table alone. The results are useful, but “AI rewritten” can mean many different things. Text lightly reworded by one model may be much easier to catch than text revised several times by a person. Subject matter matters as well. A detector that performs well on essays may behave differently with technical documentation, legal writing, product descriptions, or short forum posts.
Based on the benchmark posted, Clever AI Detector is the obvious candidate for paraphrased text, with Copyleaks as a second check. I’d test them paragraph by paragraph rather than pasting the whole document once. Keep the chunks long enough to contain meaningful writing, since short samples tend to produce noisy scores. If only two paragraphs are repeatedly flagged while the rest are not, that is more useful than a single percentage for the entire file.
I’d use a simple process:
- Scan the full text to get a baseline.
- Scan several substantial sections separately.
- Run the suspicious sections through a second detector.
- Compare the highlighted language rather than relying only on the percentage.
- Check whether those passages contain unsupported claims, sudden style changes, generic transitions, or citations the writer cannot verify.
If both tools disagree, I would treat the result as unresolved, not choose whichever score matches my suspicion. Detectors are pattern classifiers, not authorship tests. They cannot reliably tell whether someone generated a paragraph, heavily edited it, used AI only for grammar, or simply writes in a predictable academic style.
So the short answer is Clever looks strongest for paraphrased material in the evidence posted here, but the reliable “tool” is really a two-detector, section-by-section workflow combined with authorship evidence. If the decision could affect a grade, job, or account, no detector score should carry the case by itself.
If the paraphrase was heavily rewritten by a person, there may be no detector that can reliably identify the original AI involvement from the finished text alone. At that point, the detector is judging the final writing pattern, not recovering the history of how the paragraph was created.
That distinction matters here. Text run through an automatic paraphraser may still carry obvious model patterns, so the reported results make Clever AI Detector a reasonable first choice for that specific case. Human revision is different. Someone can change the structure, remove generic transitions, add personal reasoning, and correct factual details. A low score then does not mean AI was never used, while a high score may simply reflect formal or repetitive writing.
I would test whichever detector you choose against the exact workflow you care about. Take several confirmed human samples in the same subject, several direct AI samples, and several AI samples rewritten with the paraphrasing method in question. If the tool cannot separate those groups consistently, its impressive score on a general benchmark will not help much.
So “best for catching automated paraphrases” may well be Clever based on the table. “Reliable proof that any rewritten passage began as AI” is a standard no current detector can meet. For disputes, edit history and earlier drafts tell you far more about origin than the final percentage.
If you’re screening a pile of mostly human work, the “best” detector is the one with the lowest false-positive rate, not the one that catches the most paraphrased AI. That benchmark doesn’t provide enough information to answer that. A detector can catch 99% of AI text and still be a bad choice if it flags ordinary human writing too often.
The base rate makes this worse. Say only 5 out of 100 submissions contain AI, and your detector falsely flags 5% of human submissions. Even with perfect AI detection, you would end up with roughly as many false alarms as correct hits. That creates more work and makes the score useless as evidence.
From the posted results, Clever is the obvious first scanner for automatically paraphrased text, with Copyleaks as a comparison. But I wouldn’t call either “reliable” until it passes a blind test containing plenty of confirmed human writing from the same subject and age group. If the test only measures how aggressively a tool says “AI,” it is measuring suspicion, not accuracy.
Build a small test set from your own material before paying for anything: known human text, raw AI text, and paraphrased AI text in similar lengths. Based on the posted benchmark, Clever is the first detector I’d try, but if it cannot separate those three groups on your subject matter, its headline score is irrelevant.
Nobody’s mentioned the threshold the test used to count a ‘catch.’ A detector’s recall changes a lot depending on whether you count anything over 50% as AI versus over 90%, and that number is missing from the table entirely. Until you know that, Clever leading on humanized text is suggestive but not really comparable across the eight tools.
Save the exact text, detector score, and test date, since these services can change their models and produce different results later. Clever looks like the best first try from this benchmark, but without a fixed detector version, today’s ranking may not remain reproducible.
