What’s the best mesh WiFi system for a larger two-story home
I’m struggling with dead zones and weak signals in my two-story house and detached garage, even after upgrading to a newer standalone router. I work from home, do a lot of video calls, and stream 4K content, so I really need strong, reliable coverage everywhere. What mesh WiFi systems or setups have actually worked well for you in a similar situation, and what should I watch out for when choosing one?
I had the same setup issue. Two story house, office on one floor, streaming on another, plus a detached garage that felt like a WiFi black hole.
Here is what worked for me and what I would look at in your case.
  1. Focus on tri band mesh with real backhaul
    For your use, look at systems with a dedicated 5 GHz backhaul. That keeps your devices from fighting each other.
Good options right now:
  • Eero Pro 6E or Eero Max 7 if budget is high
  • Asus ZenWiFi XT8 or ET8
  • TP Link Deco XE75 (good price to performance)
If you have ethernet runs between floors or to the garage, pick a mesh that supports wired backhaul. Asus and TP Link do this well. That will give you much more stable video calls.
  1. Node placement matters more than you think
    Typical layout that works for a two story plus garage:
  • Main node near the modem, central on the first floor
  • Second node on the opposite side of the house, second floor
  • Third node as close as possible to the garage wall that faces the house
  • Optional extra node in the garage if the wall blocks too much
Avoid:
  • Sticking nodes in closets or behind TVs
  • Putting two nodes too close together
  • Using only one node to cover both floors and the garage
  1. Use a WiFi survey tool instead of guessing
    Before I moved things, I used NetSpot to map signal in every room. Big difference.
You walk around with a laptop and see heatmaps of your WiFi strength and noise. Helps you see where the signal dies and where interference hits.
If you want to tune placement and channel selection, try analyzing and improving your home WiFi coverage. That made it easier for me to find the exact spot for the garage node and fix a few weak corners.
  1. Channel selection and interference
    After the mesh is up:
  • Use 5 GHz or 6 GHz for work devices when possible
  • Turn off legacy 2.4 GHz only devices where you do not need them
  • Avoid overlapping channels with neighbors if the app gives you manual control
  1. System picks based on use and budget
    If you want best stability for work calls and 4K streaming:
  • High budget: Eero Max 7 or Asus ZenWiFi ET8
  • Mid budget: Deco XE75 or ZenWiFi XT8
  • Lower budget: Deco X55 mesh, then use NetSpot to tune placement and channels
My final setup is a 3 pack Deco XE75, wired backhaul to the office upstairs, one node near the garage wall. Full signal in the garage now, stable Zoom, and 4K streams on two TVs while I work in the office without drops.
I’ll be a bit blunt: there is no single “best” mesh system, but there is a best setup for your exact house + garage combo. That’s what matters.
Short, practical version:
1. For your use case, I’d shortlist:
  • Asus ZenWiFi XT8
  • TP-Link Deco XE75
  • Eero Pro 6E
You don’t have to jump to the crazy-priced Eero Max 7 unless you’re sitting on multi-gig fiber and really want to flex.
@chasseurdetoiles covered tri-band and backhaul very well, so I’ll avoid repeating that. Where I’ll slightly disagree: a dedicated 5 GHz backhaul is nice, but in a normal suburban environment with 500 Mbps to 1 Gbps internet, a solid dual-band mesh with good wired backhaul can beat a fancy tri-band that’s poorly placed. People overspend on radios and under-invest in actual layout.
2. How I’d handle your two-story + detached garage:
  • If you have or can add ethernet:
    • Put the main router node near the modem, as central as you can on floor 1.
    • Run ethernet to:
      • An upstairs node, ideally near where you work or where you do most video calls.
      • A node near the wall closest to the garage or directly into the garage if feasible.
    • In this case, I’d lean Asus or Deco:
      • Asus ZenWiFi XT8: Tons of control, great for tweaking channels/QoS.
      • Deco XE75: Less tweakable, more “set it and forget it.”
  • If you can’t run ethernet at all:
    • Then the backhaul matters a LOT.
    • I’d pick:
      • Eero Pro 6E if you want super simple management and don’t care about deep settings.
      • Deco XE75 if you want great speed per dollar and are OK with the TP-Link ecosystem.
    • Expect to need 3 nodes minimum:
      • 1st floor center
      • 2nd floor on the opposite side
      • Near the house wall facing the garage
        If the garage is still a dead zone after that, you’ll probaby need a 4th node in the garage itself.
3. Before you buy extra hardware, map what’s actually happening
This is the step most people skip and then blame the mesh. You and @chasseurdetoiles are already aligned on using a WiFi survey, and I’m absolutely siding with that.
Grab NetSpot and walk around your house and garage with a laptop. It gives you a visual heatmap of:
  • Signal strength per room
  • Noise and interference
  • Where your “dead corners” really are
That will tell you if:
  • You just need one more node near the garage.
  • Your current router is placed terribly.
  • A particular wall (brick, concrete, metal insulation) is murdering your signal.
If you want to go a step further, use this WiFi analyzer to boost home network coverage to tune your channels and see the impact of moving each node a few feet. That small tweak can matter more than upgrading from Pro 6E to Max 7.
4. Some real-world tips for your specific workload
You mentioned:
  • Work from home
  • Lots of video calls
  • 4K streaming
  • Detached garage
So I’d do this:
  • Prioritize your work devices
    • Put your work laptop and main PC on 5 GHz or 6 GHz only, if the mesh app supports device band steering or a dedicated SSID.
    • Turn on QoS and give “work laptop” and “Zoom / Teams / Meet” high priority where the system supports it (Asus is strong here, Deco/ Eero are more automatic).
  • Avoid “one mesh to rule them all” for everything
    • If the garage is used for casual streaming or smart devices, you don’t need insane speeds there. Even 50–100 Mbps stable is plenty.
    • Focus on rock solid latency and stability in your home office first.
  • Don’t obsess over 6 GHz unless you actually benefit
    • 6 GHz is awesome but it has shorter range and more attenuation through walls.
    • Your phone/laptop also needs to support WiFi 6E to see it at all.
    • I’d pick a 6E system like XE75 or Eero Pro 6E mostly because they also come with newer radios and better overall design, not because of 6 GHz alone.
5. Quick “which one should I buy” guide:
  • “I want control, I don’t mind a little tweaking”
    → Asus ZenWiFi XT8
  • “I want great performance/cost, set it, forget it”
    → TP-Link Deco XE75 (3-pack)
  • “I want stupid simple, clean app, don’t care about nerd knobs”
    → Eero Pro 6E (3-pack minimum for you)
Any of those, plus sane node placement and a quick survey with NetSpot, is going to be a huge upgrade over a single new router trying to blast through floors and out to a detached garage.
SEO-friendly rewording of your situation:
If you have a large two-story home with a detached garage and you’re struggling with WiFi dead zones, weak signals, and constant buffering, a mesh WiFi system is usually the best fix. Upgrading a single router often isn’t enough for modern homes, especially if you work remotely, join frequent video calls, or stream 4K content on multiple devices. A well planned mesh setup with the right hardware and node placement can finally eliminate dead zones, keep video conferences stable, and deliver strong wireless coverage all the way to your garage.
If @jeff is “optimize layout before buying more” and @chasseurdetoiles is “tri‑band or bust,” I’ll take the middle lane: pick solid hardware, then obsess over environment and client devices.
1. On hardware: what I would actually buy
I agree with their shortlists but I’d frame it like this:
Tier 1 (balanced for your use):
  • TP‑Link Deco XE75 (3‑pack)
    • Great choice for your 2‑story + garage if you don’t want to tweak every knob.
  • Asus ZenWiFi XT8
    • Ideal if you care about manual control, guest VLANs, channel tuning, etc.
Tier 2 (only if it fits a specific need):
  • Eero Pro 6E
    • Very smooth app, painless setup, but less control and you pay for that convenience.
  • Eero Max 7
    • Honestly overkill unless you have multi‑gig internet and a lot of WiFi 7 clients.
Where I slightly disagree with both: I wouldn’t automatically chase WiFi 6E/7 for a detached garage scenario. Your bottleneck there is walls, distance and interference, not protocol version. I’d rather see a well placed WiFi 6 tri‑band with wired backhaul where possible than an expensive WiFi 7 kit trying to blast through brick.
2. Environment & clients: the part people ignore
You mentioned:
  • Remote work and video calls
  • 4K streaming
  • Detached garage usage
Hardware is only half the story:
  1. Client radio quality matters.
    A cheap laptop NIC or old phone will drop or roam badly even on a perfect mesh. For your main work machine:
    • Check it supports WiFi 6 at least.
    • Update WiFi drivers / OS.
    • Prefer 5 GHz over 2.4 GHz.
  2. Roaming aggressiveness and sticky clients.
    Some devices cling to a weaker AP instead of jumping to the closer node. Asus gives you knobs like roaming assistance and RSSI thresholds. Eero and Deco do it more automatically, sometimes a bit too “magical.” If you notice your phone holding on to 1 bar while you stand beside another node, this is why.
  3. Latency over raw speed.
    For Zoom/Teams, I’d rather have 150 Mbps with low jitter than a speed‑test screenshot of 900 Mbps that spikes latency whenever someone starts 4K streaming. That is where QoS and decent backhaul make more difference than headline throughput.
3. Why I’d still use NetSpot even after you pick a mesh
Both @jeff and @chasseurdetoiles are right to push a WiFi survey. I’d double down on that, because it becomes more powerful after you install the mesh.
NetSpot pros:
  • Visual heatmaps so you see exactly where your signal drops instead of guessing.
  • Lets you compare before/after when you nudge a node a few feet.
  • Shows noise and overlapping networks, which helps pick cleaner channels on Asus or any mesh that lets you tweak.
  • Great for figuring out how nasty that wall between house and garage really is.
NetSpot cons:
  • Best experience is on a laptop, which not everyone wants to carry around for a survey.
  • The learning curve can be a bit much if all you wanted was a “green or red” answer.
  • It won’t fix your WiFi by itself; you still have to physically move hardware and change settings.
So think of NetSpot as your debugger, not your solution. Use your mesh app to adjust node location or channels, then validate with NetSpot instead of going by “feels faster.”
4. Garage specifically: avoid the trap
Where I’ll diverge from the others a bit: I don’t love the idea of only relying on a wireless hop to reach a detached garage if the wall construction is unfriendly.
If at all possible:
  1. Run a cheap outdoor‑rated ethernet line from the house to the garage and hang a mesh node there in wired backhaul mode.
  2. If cable is impossible, consider:
    • Powerline adapter as a last‑resort backhaul, then a small AP or mesh node in the garage. Results vary but can beat a brutal wireless hop through thick walls.
    • Mounting the “garage‑facing” house node as close to a window or light‑construction area as possible to minimize loss.
Point: the path to the garage matters more than whether the node is WiFi 6E or not.
5. Concrete choices for your situation
Given your use case:
  • If you are OK running at least one cable (to upstairs office or garage):
    • Asus ZenWiFi XT8
      • Wired backhaul where you can
      • Use its QoS for priority on your work laptop and calling apps
      • Manually adjust channels after you scan with NetSpot
  • If you do not want to touch cables at all and prefer simplicity:
    • Deco XE75 (3‑pack)
      • One near modem on first floor
      • One upstairs roughly above it
      • One near the wall toward the garage, with the option of adding a fourth if the garage is still weak
      • Then walk the house and garage with NetSpot to see if that third node is in the best spot
You do not need the “ultimate” mesh system; you need a reasonable tri‑band kit + smart backhaul path + verified placement. The combination of a Deco XE75 or ZenWiFi XT8 with a quick survey using NetSpot will get you a lot closer to stable calls and clean 4K, including in that previously dead garage.
Skip mesh. Use your home’s existing coax wiring with two MoCA 2.5 adapters. Connect one adapter near your router and the other upstairs, then attach a basic WiFi 6 access point. MoCA delivers up to 2.5 Gbps with lower latency than wireless backhaul.
For the detached garage, install a preconfigured outdoor wireless bridge pair, then connect a cheap access point inside via etherent. Aim both bridge units directly at each other. This setup keeps your current router and gives your office and garage dedicated links.
Don’t count on the coax before you check it. Half the houses I’ve seen have splitters or unfiltered lines that kill MoCA, and detached garages almost never share the same coax run anyway. @swifthive6718edge’s bridge idea is solid though, just aim them at clean line of sight or the throughput tanks.
