What’s the easiest way to record a phone call on my iPhone?
I need to record some important business calls on my iPhone for reference, but I’m confused by all the apps and settings out there. Some say it’s not possible without using another device, others mention third‑party apps or voicemail tricks. I’m also worried about doing it legally and clearly enough so the audio is usable later. Can anyone walk me through a reliable, legal method to record calls on an iPhone and what tools you actually use?
Short version. On iPhone you have 3 sane options. None are perfect.
  1. Use a second device
    This is the simplest.
• Put the call on speaker on your iPhone.
• Put another phone, laptop, or recorder next to it.
• Use the Voice Memos app or any recorder on the second device.
Pros
• Free.
• No account weirdness.
• Works for incoming and outgoing calls.
Cons
• Audio quality depends on speaker and room noise.
• Other person might hear the speaker and ask about it.
  1. Use a “3‑way calling” recording app or service
    These services work like this.
    • You call a special number first. That number records.
    • Then you add your real caller as a third person.
    • The service merges the calls and stores the recording in the app or online.
Popular examples
• TapeACall
• Rev Call Recorder
• Google Voice (in some regions, incoming calls only, announces recording)
What to look for
• Transparent pricing. Avoid apps that hide subscription costs until checkout.
• Where recordings are stored. App servers vs iCloud vs your device.
• Export options. You want to save as MP3 or M4A, not get stuck in the app.
Pros
• No extra hardware.
• Both sides usually recorded with clearer audio than speakerphone.
Cons
• Needs 3‑way calling support from your carrier. Some prepaid plans do not support it.
• Setup is awkward if you need to start recording in the middle of a call.
• Trust issue. Your business calls sit on someone else’s servers.
  1. Use VoIP or meeting tools instead of normal phone calls
    If these are “business” calls, this is often the cleanest approach.
Options
• Zoom, Google Meet, Microsoft Teams, Webex.
• Business VoIP apps like RingCentral, Dialpad, Vonage, etc.
How to use
• Schedule or start a meeting.
• Invite the other person by link, or use their dial‑in number if they do not use the app.
• Hit Record inside the meeting.
• Download the audio file later.
Pros
• Clear recordings.
• Easier to organize and archive.
• Better for repeat business calls.
Cons
• Slightly more setup for the other person.
• Some clients dislike joining links for “simple” calls.
Legal stuff
Not legal advice, but you need to think about this.
• Many US states use one‑party consent. You can record if you are part of the call.
• Some states use two‑party or all‑party consent. Everyone must agree.
• Some countries have strict rules.
Safe habit
• Say something like “Before we start, I want to record this call for reference, is that ok with you?”
• If they say no, stop recording.
Practical suggestion for you
If these are occasional calls and you feel overwhelmed by apps
→ Use speakerphone plus another phone with Voice Memos.
If you record business calls often
→ Set up a VoIP or meeting tool and make that your default for “important” calls.
If you are stuck with normal carrier calls and want everything on the iPhone
→ Try a 3‑way recording app like TapeACall, test it once with a friend, and see if your carrier supports it.
Test your setup before any important call. Do a 1 minute test with a friend, play back, check audio level, and fix distance and volume if needed.
Short version: there is no magic “one tap and it secretly records normal iPhone calls” solution. Apple blocks that for regular cellular calls, so every method is basically a workaround.
Since @chasseurdetoiles already covered the big three (second device, 3‑way apps, VoIP/meeting tools), here are some alternative angles and a few spots where I disagree a bit.
1. Use a dedicated call-recording phone number
Instead of a 3‑way app on the iPhone, you can get a business / VoIP line that auto‑records all calls on that number:
  • Services like RingCentral, Zoom Phone, Dialpad, etc. let you:
    • Get a real phone number
    • Turn on automatic recording for all calls
    • Access recordings in a web dashboard or app
How you’d use it with your iPhone:
  • Install the provider’s iOS app
  • Make/receive your “important” calls from that app instead of the default Phone app
  • Let the provider handle recording in the background
Why this might be easier than juggling 3‑way call apps:
  • You don’t have to remember to conference in a recording line every time
  • No awkward “hold on while I add the recorder” moment
  • Better for recurring clients and long‑term reference
Downsides:
  • Usually a monthly fee
  • Your number might change unless you port your existing one
  • Your recordings live on their servers, so you need to be OK with that
Honestly, for business use, this is often smoother than the average 3‑way recording app.
2. Use voicemail as a crude recorder
Weird trick, not ideal, but it does work in some cases:
  • Call your own number and get to your voicemail
  • Three‑way / merge your voicemail with the other person
  • The whole thing gets recorded as a voicemail
  • Afterward, save / export voicemail audio
Issues:
  • Call setup is clunky
  • Max voicemail length can cut you off mid‑call
  • Carriers and visual voicemail behavior differ
I’d only use this as an emergency backup when you don’t trust a third‑party app and don’t have a second device handy.
3. Bluetooth hardware solution
Instead of putting the phone on speaker next to another device (like @chasseurdetoiles suggested), a slightly more “pro” variant is:
  • Get a Bluetooth call recording adapter / headset that:
    • Connects to your iPhone via Bluetooth
    • Has a built‑in recorder or line out to another recorder
Use case:
  • Pair it with your iPhone
  • Take calls through the Bluetooth device
  • Hit record on the device or attached recorder
  • Better sound than speaker + mic in a noisy room
  • You don’t have to blast the call on speaker
  • Extra gadget to buy and charge
  • Still not “all on the iPhone”
  • Setup can be fiddly
If you do a lot of calls on the move, this can be less annoying than balancing a second phone near your iPhone speaker.
4. For truly occasional, important calls
If this is like “once every month I need it recorded” and you hate complexity:
  • I actually disagree slightly with the idea that a second device is always the simplest.
  • For a rare, planned, important call:
    • Schedule it as a Zoom / Meet / Teams call
    • Send the person a simple “Here’s a link, you can just tap and join on your phone, no account needed”
    • Hit Record
Yes, some people roll their eyes at a meeting link for a “simple” call, but if it is important enough that you’re stressing over recording, this is a fair tradeoff for clarity and reliability.
5. Plain reality check
If you want:
  • Native Phone app
  • One‑tap recording
  • No third‑party
  • No extra hardware
  • No VoIP
That does not exist on iPhone because of Apple’s restrictions.
Pick your poison:
  • Simplicity but lower quality: second device / Bluetooth recorder
  • All‑in‑one on the iPhone but more steps: 3‑way recording apps, voicemail trick
  • Cleanest long‑term business solution: VoIP / business number with automatic recording
6. Super basic legal sanity
Not legal advice, but:
  • At minimum, google: “call recording law [your state/country]”
  • When in doubt, say something like:
    “Just a heads up, I’m recording this call so I can refer back to details, that OK?”
  • If they hesitate or say no, do not try to get clever or sneaky. That’s how you end up in stories you don’t want to be in.
If I had to pick for myself, for actual business:
  • Frequent client calls: a VoIP business number with auto‑recording, used through its iPhone app
  • Occasional “once in a while” calls: Zoom / Meet link and record there
  • Rare off‑the-cuff “I really need this”: second phone with Voice Memos in a quiet room
Everything else is just variations of those three ideas.
Short version: everything @voyageurdubois and @chasseurdetoiles wrote is accurate on how to capture the audio. I’d focus on a different decision: “how do I make this boring and automatic so I don’t screw it up on an important call?”
1. Think in “workflow,” not in gadgets
Instead of asking “what’s the easiest way to record a phone call on my iPhone,” decide:
  • Are these calls planned or spontaneous?
  • Are they with repeat clients or random people?
  • Do you need to prove what was said, or just remember details?
That choice affects which of their methods is actually “easy” for you.
For example, I slightly disagree with the idea that a second device is always the simplest. It is simple technically, but in real life people forget to:
  • Charge the second device
  • Hit record in time
  • Check that the room is quiet enough
So “simple” often turns into “I missed the first 5 minutes and the rest sounds like a lunchroom.”
If this is real business and not a one‑off, the most painless long‑term setup is usually:
  • Use a dedicated business / VoIP line with automatic recording
  • Or route important conversations through Zoom / Teams / Meet
You trade a tiny bit of friction at the start for huge reliability later.
2. Treat privacy and storage as part of the choice
Both @voyageurdubois and @chasseurdetoiles touch on where recordings live, but I’d put that front and center:
  • Second device: stays with you, but messy to organize
  • 3‑way apps: sit on a company’s server, often tied to a subscription
  • VoIP / meeting tools: also server based, but usually with better retention policies and admin controls
If these are sensitive business calls, you want:
  • Clear export options (M4A / MP3)
  • A way to delete from the provider
  • Some basic access control if anyone else touches the account
“Easiest” is not worth much if a random support rep or ex‑employee can dig through all your calls.
3. How I’d actually set it up in practice
If I were in your shoes and had to pick one main approach:
  • For frequent, planned business calls:
    • Use a VoIP or business phone solution with auto‑recording via its iPhone app
    • Tell clients: “This line is recorded so I can take accurate notes. OK?”
    • Keep the default Phone app only for non‑recorded personal calls
  • For truly occasional “I suddenly need this one saved”:
    • Use the second device method they described
    • But test once and keep a note in your phone:
      • “Put iPhone on speaker, set second phone 15–20 cm away, test levels”
That way you are not scrambling to remember a 3‑way merge sequence while someone waits on the line.
4. Where I’d be cautious
  • Relying on clever tricks like voicemail merges as your primary method
  • Expecting a 3‑way recording app to be fast enough for mid‑call “oh wow I need this recorded” moments
  • Assuming “if it is in the App Store it must be legally safe where I live”
Call recording on iPhone is basically a set of compromises. The real win is picking one compromise and turning it into a repeatable routine so you are not experimenting five minutes before an important deal discussion.
